HELP!
Forum topic by ShopWench posted 01-30-2012 12:00 AM 1045 views 0 times favorited 4 replies Add to Favorites Watch
View ShopWench's profile
ShopWench
71 posts in 2338 days
01-30-2012 12:00 AM
Topic tags/keywords: bandsaw lathe
I am newly fascinated by woodworking! That being said, I am also a bit overwhelmed. I have learned, sort of the hard way, that good tools are vital. BUT I do not have unlimited funds to dump into this. I was given a lathe from harbor freight, it works fine for small projects of the spindle type, but beyond that it’s a mess. Also, I got a second hand bandsaw that I might as well toss in the yard. SO, I would really like some advice about best value on wood lathes and bandsaws. I understand that a decent tool will not be cheap, but I don’t want to over spend either. I want to turn bowls and hollow forms, cut blanks, and outlines for hand carvings. I have a Ridgid drill press that seems good. Also, I have an outlet store to get 14”band saw, but the review I read on here was not making me want to run out and get it. I would be grateful for some experienced advice!
-- Nancy
View JAAune's profile
JAAune
1802 posts in 2343 days
#1 posted 01-30-2012 12:17 AM
Best value is to be had from auctions, garage sales, Craigslist and other outlets of used goods. Unfortunately that is a time-consuming way to acquire tools and you do have to know what to look for.
When you get a bandsaw I recommend sticking with the simplest guide system. It will keep the price down and happens to be the least frustrating to work with. Here’s an example of a basic guide system that works well.
Bandsaw Guides
The more expensive saws tend to have roller bearings on the side and they require constant cleaning and/or replacing.
A good bandsaw blade is a necessity. Properly adjusted guides and a good blade will allow even a cheap saw to cut well. The blades don’t have to be fancy or expensive. They do need to be made from decent steel and have a really good weld joint. If the weld is done properly the blade will seem like a continuous band with just the grind marks to indicate where it was welded. No kinks or misaligned teeth.
View StumpyNubs's profile (online now)
StumpyNubs
7601 posts in 2827 days
#2 posted 01-30-2012 12:35 AM
Watch our videos... do a lot of “make your own machines” etc. Forr example, during the next couple months we’ll be building a big tool cabinet, making our own bench mounted biscuit joining machine, building a screw advancing, quick release box joint cutter, making a mortising machine and pattern router, and starting on our homemade, wooden band saw.
And if you don’t learn anything, you get your money back… because it’s free…
-- Subscribe to "Stumpy Nubs Woodworking Journal"- One of the crafts' most unique publications: http://www.stumpynubs.com/
View Bill White's profile
Bill White
4949 posts in 3987 days
#3 posted 01-30-2012 12:47 AM
Don’t be hasty in your tool buys. My advice is to stay away from the crappy stuff you’ll find at some of the import/discount sellers. Also, be aware of some of the stuff offered by the borgs. Newer tooling offered is for folks who MIGHT use a tool infrequently.
That being said, there are a few items (HF dust collector as an example) that will give ya good bang for the buck. I try to find older machines/hand tools on offer from the web.
Stay in touch with the Jocks, and ask frequent questions about a potential purchase. You won’t be uninformed.
Bill
-- bill@magraphics.us
View RogerM's profile
RogerM
792 posts in 2425 days
#4 posted 01-30-2012 04:15 AM
For a new bandsaw, one of the better values is the Rikon 14” Deluxe. Coupled with a Timberwolf or a Highland Hardware “Wood Slicer” blade, this saw is a lot of saw for a modest amount of money.
-- Roger M, Aiken, SC
