Tuning a Block Plane - Is Silicon Carbide Sandpaper required?
« back to Hand Tools forum
Forum topic by NoviceWoodworker posted 01-29-2012 02:21 PM 1035 views 0 times favorited 2 replies Add to Favorites Watch
View NoviceWoodworker's profile
NoviceWoodworker
17 posts in 2334 days
01-29-2012 02:21 PM
I purchased a block plane and while watching an episode of Woodsmith Shop they discussed tuning the block plane. They mentioned that you should draw a squiggly line across the sole of the plane and use 220-grit silicon carbide sandpaper for tuning the base of the plane. I have 220-grit sandpaper I had already purchased and was wondering if it would work (it is 3M garnet sandpaper for sanding bare wood surfaces purchased from Amazon.com). I wasn’t sure if there was a big difference in these two types. Thanks.
2 replies so far
View chrisstef's profile
chrisstef
17312 posts in 2976 days
#1 posted 01-29-2012 02:41 PM
you’ll be just fine with the sandpaper you have i wouldnt sweat it at all. Once you get above 220 id go with the wet / dry sandpaper for sharpening the iron if you’re going the scary sharp route. Good luck on the restore.
View Bill White's profile
Bill White
4910 posts in 3930 days
#2 posted 01-29-2012 05:50 PM
I don’t know how well garnet paper will work.
Regular wet or dry will be better in my opinion.
Bill
-- bill@magraphics.us
