Router table. How high is too high.
Forum topic by Eric posted 01-29-2012 07:27 AM 1393 views 0 times favorited 6 replies Add to Favorites Watch
View Eric's profile
Eric
55 posts in 3324 days
01-29-2012 07:27 AM
Topic tags/keywords: router
I came across a router table that I just had to build. Once it was all said and done the router top is 46” high. So much for detailed drawings, which I never use. Just a few notes and sketches in the binder.
It”s just a tad too high? A quick fix would be to remove the swivel locking casters, and that would drop it down to ~41.5” high.
My main concern is being able to put downward pressure when I am pushing wood against the fence.
Any other concerns from the community?
So, is 41.5” still too high? I could shorten the height of the draw cabinet! Maybe! Good thing I have not made the drawers yet.
Any input or ideas?
Eric
-- Eric "That's all very well and human, but when will you stop having to apologize and start doing your very best you can? When will you begin?"
117417 posts in 3815 days
#1 posted 01-29-2012 07:47 AM
Only you know if it’s right for you Eric. I would check other pieces of equipment in you shop and see how it feels ,your jointer takes a similar action to use. If you feel good about it’s height then duplicate it’s height for your router table.
View JAAune's profile
JAAune
1854 posts in 2554 days
#2 posted 01-29-2012 07:47 AM
Depends upon your height. I like my router tables at waist level.
View tom427cid's profile
tom427cid
294 posts in 2708 days
#3 posted 01-29-2012 08:00 AM
Hi,
I have a router in a stand that is about that high. Its primary use is for a special cut when I make banding.To offset the tendency of the cabinet to tip I store my steel and cast iron flats and blocks(use for weight doing veneer repairs). Short of that a couple of cinder blocks might help. However if you are doing heavy cutting-pushing against the fence-I think that you might be a bit high.
Hope this helps.
tom
-- "certified sawdust maker"
View Danpaddles's profile
Danpaddles
573 posts in 2550 days
#4 posted 01-29-2012 08:03 AM
I am at 43 1/2 for the last 10 years. There are a few operations where I have to move the whole thing away from the light I have mounted over the table. Think- board on end. You could run out of head room!
-- Dan V. in Indy
View Sarit's profile
Sarit
550 posts in 3377 days
#5 posted 01-29-2012 09:21 AM
I’m confused, is it already built or are you planning to build it?
If you are planning to build it, then like other said you should test out what height feels comfortable to you and modify the designs to fit how your body wants to work. In general, I believe the larger the pieces you work with, the lower the table should be, down to about tablesaw height (32-34”). So if you’re making small boxes, then 46” wouldn’t be totally unreasonable. If you’re trying to rout chamfers on an assembled blanket chest then that’s too tall (unless you are > 7’ tall).
View DIYaholic's profile
DIYaholic
19743 posts in 2913 days
#6 posted 01-29-2012 04:54 PM
If you already made it…...just wear a pair of sheetrockers stilts! Lol.
Truely, I hope you find a workable solution.
