Need info on old homecraft bandsaw tires
Forum topic by TITAN2 posted 01-28-2012 10:39 PM 1571 views 0 times favorited 1 reply Add to Favorites Watch
View TITAN2's profile
TITAN2
5 posts in 2708 days
01-28-2012 10:39 PM
Hello I have an old Delta homecraft bandsaw I picked up at an auction I need to replace the tires but am not sure what size tires I need or were to get them from, here is some info on the saw, wheels are 9 3/4” in diameter and 3/4” wide groove in wheels not sure of model # only thing I could find that may be it is HBS-750 serial # N-1220, of course it has rubber tires on it now should I replace with the same or go with poly. I believe the blade size is 69” or possible 70”will be replacing that as well.any help or info would be greatly appreciated.
Thanks
—TITAN2 Delaware
-- TITAN2 Delaware
1 reply so far
bandit571
19227 posts in 2591 days
#1 posted 01-28-2012 11:48 PM
On the 12” three wheel bandsaw I have, I use belts from …......DirtDevil sweepers. Yep, a tight fit, but they work. Suggest you take a belt/tire from YOUR bandsaw, and wander into a store that sell such belts. You MIGHT be surprised…
