Sander
Forum topic by BuyoMasilla posted 01-28-2012 06:59 AM 1027 views 0 times favorited 5 replies Add to Favorites Watch
View BuyoMasilla's profile
BuyoMasilla
104 posts in 2456 days
01-28-2012 06:59 AM
Greetings,
I have been keeping an eye out for a bench top belt sander. From my wood magazine I have saved a coupon and hope to pick up HF 4” belt/6”disk unit for close to fifty dollars. As I am waiting to make that purchase I found on a local online site an old ryobi oscillating spindle sander and though I has no opulence, I jumped in it.
Since the money I was hoping to use on the belt sander went to the oscillating, I’m trying to come up with ideas. As I had to go by the orange big box for a honey do, as usual, took a stroll through the tools dept. Based on some of what I saw, I was left wandering and now turn to you with a question.
They had a 10 inch masonry blade for close to four us dollars. What do you think? Can I slap a sticky sand paper to that and throw it on the table saw for a disk sander? Anyone tried that before?
If you will, please share your thoughts.
Thanks for reading, Mario
You can call me Buyo Masilla
-- Dreaming of the day I might joint two pieces of wood square..........
5 replies so far
View KOVA's profile
KOVA
1362 posts in 2287 days
#1 posted 01-28-2012 07:31 AM
View DIYaholic's profile
DIYaholic
19539 posts in 2583 days
#2 posted 01-28-2012 07:38 AM
The masonary blade may be too brittle to work. I know I would not do it.
Check this out!
Perhaps this will do.
View ConcordCarpenter's profile
ConcordCarpenter
6 posts in 2849 days
#3 posted 01-28-2012 03:11 PM
I’m not sure the masonry blade is the right material. There is a company called Final Cut that makes a saw blade with sandpaper on it. Look at how they do it before proceeding. http://www.finalcutblade.com/
-- A Concord Carpenter ~ Practical Solutions To Everyday DIY Challenges
View Dusty56's profile
Dusty56
11819 posts in 3596 days
#4 posted 01-28-2012 05:25 PM
Depending on the RPM of your saw and the grit of paper you use , you may just end up burning the wood versus actually sanding it. Most disc sanders run at 1725 RPM. Most table saws double that.
View Mauricio's profile
Mauricio
7144 posts in 3060 days
#5 posted 01-30-2012 04:39 PM
Hey Buyo, I would first want to know what you are going to use it for?
I know you’re on a budget like I am so I would hesitate to buy a belt sander that does very limited things. Depending on what your going to use it for there may be other more versatile tools. I don’t own a bench top belt sander.
For example if you just want to smooth curves, I would rather buy a spoke shave. With that sander your going to need dust collection if you don’t have it yet. Spoke shave is very versatile works faster and is a lot more fun.
Also if you have a drill press then buy drums for that instead. If you don’t have a drill press then get that first.
If you just want to smooth the face of boxes and small projects like that I would get you a Stanly #4 hand plane that can be used for many more things than just surfacing wood.
If you have a hand held belt sander there are easy jigs you can make to hold it on its side to sand small parts.
