DC for under $750? Help me spend it...
Forum topic by WorkTheWood posted 01-28-2012 04:24 AM 1246 views 0 times favorited 8 replies Add to Favorites Watch
View WorkTheWood's profile
WorkTheWood
35 posts in 2522 days
01-28-2012 04:24 AM
I have really been considering a Penn State 3.5HP cyclone for my soon-to-be basement shop.
http://www.pennstateind.com/store/TEMP1535S.html
I want a powerful machine that will capture a lot of dust effectively. My shop is 450’ish square feet and will eventually have a table saw, 8” jointer, 12” planer, Router (mounted in a table), SCMS, Band-saw, Drill Press.
My frugal-side wants to consider lower cost options so I can put the money saved towards other tools.
What would you suggest that would do a great job, and keep the total spend under 750?
-- -- Lou Stagner
8 replies so far
View Viking's profile
Viking
880 posts in 3316 days
#1 posted 01-28-2012 04:31 AM
Harbor Freight 2 HP DC.
Wynn 35A canister filter.
30 gallon trashcan pre-separator.
Spend a bit on DC piping.
Less than $500 and all the performance you need!
Donate the $250+ you save to LJ’s.
Lots of posts and reviews on this setup on LJ’s
Good luck!
-- Rick Gustafson - Lost Creek Ranch - Colorado County, Texas
View JAAune's profile
JAAune
1826 posts in 2438 days
#2 posted 01-28-2012 04:44 AM
Under $750 you’d have to forget about a cyclone unless you’re willing to settle for something like the 1.5HP Grizzly. I wouldn’t recommend a low-powered cyclone unit though. Their design requires a beefier motor to generate the needed cfm through the cyclone. My recommendation is 3HP minimum for cyclone units if you intend to run a fair amount of pipe.
I have a 1.5 collector with 1-micron bags that works fine when setup with a short run of hose to the machine. It’s definitely not capable of a full shop piping system. It would be a decent option for a portable system that gets moved from one machine to the next. A unit like that costs around $200-500 depending upon make and model.
On that note, I should probably mention that I’m not 100% satisfied with my purchase. When I bought it I hadn’t seen any of the short cyclone units that exist now and can fit in a typical garage. In the near future I intend to upgrade to a cyclone since I eventually hope to achieve air quality standards similar to that recommended by Bill Pentz. The 1 micron felt bag needs to be cleaned often and it emits fine dust whenever I whack the felt. I could upgrade it with finer filters and a Thien baffle but then I’d probably lower the cfm too much to run a full pipe system.
View Scot's profile
Scot
344 posts in 3517 days
#3 posted 01-28-2012 04:56 AM
Look at my post on my new work shop. the Cyclone separator cost me $150 on ebay. They guy that made it still sells them on ebay and has added a couple of smaller sizes. I think he has one made to fit on top of a five gallon bucket. But check your machinery needs, just because you may be only running only one machine at a time doesn’t mean you don’t need a high cfm machine. The way Delta designed the ducting in the new unisaw it needs a little more air moving to work effectively, 750 cfm just didn’t cut it. That said the HF 2 HP model for around 150.00 on sale works great. And leaves a few bucks in your budget for the cyclone separator and various other cool shop toys !
-- If the old masters had power tools, they would have used them. So get off your damn High Horse.
WorkTheWood
#4 posted 01-28-2012 04:05 PM
I forgot to mention I already have the HF 2HP unit. I just didn’t think it would be powerful enough to do a good job in a shop of my size… I am off to check out the post on your new shop MoPower. Thanks!
-- -- Lou Stagner
View Scot's profile
Scot
#5 posted 01-28-2012 04:13 PM
The 2HP unit works great, I think it moves around 1800-2000 cfm. Look on ebay for the cyclone separator and you’re all set.
View kizerpea's profile
kizerpea
775 posts in 2489 days
#6 posted 01-28-2012 04:18 PM
LOU….check my projects. i built my own cyclone, just takes a little time..i have a 1200 cfm jet blower does my 20×46 shop just fine an have some big tools.
-- IF YOUR NOT MAKING DUST...YOU ARE COLLECTING IT! SOUTH CAROLINA.
View Scot's profile
Scot
#7 posted 01-28-2012 05:22 PM
I just went on ebay to make sure the seller I’ve been bragging about is still there and he is. He now has two models, a small one for 87.00 that sits on top of a 5 gallon bucket and works with a shop vac, and a large one for 199.00, this the one I have and it is worth every penny. I have used it with both 2 & 3 hp blowers and works great with both.
I tried to set up a link but couldn’t get it to work. Just do a search for Cyclone Separator and you will find it.
WorkTheWood
#8 posted 01-29-2012 11:12 PM
Thanks for the heads up on the ebay seller… I am going to look into that further.
-- -- Lou Stagner
