| Forum topic by Hillsboro | posted 507 days ago | 1833 views | 0 times favorited | 34 replies | ![]() |
507 days ago |
OK….so I screwed up. Built a rather large box of tiger maple (12×9). When I glued it up I checked it to be sure it was square…..all seemed right. However, this morning when I went to check, the box is now approximately 1/16 inch out of square in opposite corners. The bottom is set in dadoes and not glued, but there is no play. Does anyone have any suggestions on if this can be rectified? If so, suggestions would be welcome. Thanks, Phil Stevens |
34 replies so far
#1 posted 507 days ago |
measure your corners, find the longer diagonal, put a clamp on it, tighten til square. It might stay, it might not, hard to say unfortunately. -- The mark of a good carpenter is not how few mistakes he makes, but rather how well he fixes them. |
#2 posted 507 days ago |
Shaving an outside of 1/16” from a finished box is an ideal job for handplanes… Inside, obviously not so much… Got planes? -- Don't anthropomorphize your handplanes. They hate it when you do that. -- OldTools Archive |
#3 posted 507 days ago |
I’ve made a lot of boxes, and have dealt with this problem more times than I’d like to admit. I have only found two possible courses of action: 1. Live with it. -- Charlie M. "Woodworking - patience = firewood" |
#4 posted 507 days ago |
Gee Charlie, that seems fairly extreme, Black-n-White thinking. Seems like he could cut it apart and make a slightly smaller box—if that were acceptable. -- "Hard work is not defined by the difficulty of the task as much as a person's desire to perform it.", DS251 |
#5 posted 507 days ago |
This sounds extreme and I don’t even know if it’ll work but could you heat it up gently? Then maybe the joints would soften enough to re-clamp. It’s a small box so it should fit inside an oven. Say 150°F or so? |
#6 posted 507 days ago |
I still dream of making a box that’s 1/16” out of square! -- "Do not speak – unless it improves on silence." |
#7 posted 507 days ago |
Thanks for all the suggestions. One thought I just had would be to use a combination of clamps and hot water to possibly loosen the joints. Thougths/comments are welcome. |
#8 posted 507 days ago |
Next time wait until the glue grabs, then take off the clamps and Sadly, this time you are out of luck but you may be able to steam |
#9 posted 507 days ago |
Cut the lid crooked to match? You won’t fix the box, unless you can live with a smaller box! You might also check if it is flat- lay it on your table saw and look for wobble. -- Dan V. in Indy |
#10 posted 507 days ago |
Depending upon the glue used the idea Jeff in Huntersville had has merit. I use a heat gun to loosen joint on chairs that need complete rebuilding. -- See pictures on Flickr - http://www.flickr.com/photos/44216106@N07/ And visit my Facebook page - facebook.com/MTEnterprises |
#11 posted 507 days ago |
I want to make sure I read this right. I once done an exercise. Seven days I tried. Seven days I failed. Then the same friend told me to do a new exercise. Pick the worst out of the boxes and show it to as many people as I could find over the next seven days and see if they could tell if anything was wrong with it. So I did. Guess how many people found the flaw in my 12×12x12 box that, only I and my friend knew, was about an eight of an inch out one way and about 3/16ths out of square the other? None. Zero. Nada. NOBODY could, even with some going over it with a fine tooth comb trying to find what was wrong with it, could find a single thing wrong with them. As my friend (a woodworker of over fifty years) told me later, the point of the two exercises was to prove the futility of trying to make a square box perfect in every way and just how much it really meant to the general public. |
#12 posted 507 days ago |
1/16 ? really? OK get a really big hammer…. -- If the old masters had power tools, they would have used them. So get off your damn High Horse. |
#13 posted 506 days ago |
First of all I would like to that everyone that provided a logical, sensible suggestion. I appreciate your help. Regarding the other comments, they were useless and unhelpful. If you cannot say something helpful, do not bother with a reply. |
#14 posted 506 days ago |
Phil, get a sense of humor, man. Do you consider William’s answer to be useless and unhelpful? He really spelled out in long form what I was trying to say in a very few words. And it’s good woodworking wisdom. We often find flaws in our own work that others will never see. Reading over all the comments, I don’t see a thing in any of them that is mean-spirited or negative. People are just offering their points of view. Take what you like and leave the rest. -- Charlie M. "Woodworking - patience = firewood" |
#15 posted 506 days ago |
Dealing with only a 1/16 out of square I would assume putting a square bottom in it would square it up? -- W James Brokenbourgh Custom furniture maker http://artisticwoodstudio.com/ |
| Forum | Topics |
Woodworking Skill Share
8842 |
Woodturning
246 |
Woodcarving
32 |
Scrollsawing
68 |
Joinery
96 |
Finishing
1597 |
3591 |
15972 |
Hand Tools
2093 |
Jigs & Fixtures
501 |
Wood & Lumber
2906 |
813 |
Focus on the Workspace
925 |
778 |
Woodworking Trade & Swap
2772 |
LumberJocks.com Site Feedback
1551 |
Coffee Lounge
6130 |
