| Forum topic by ssnvet | posted 483 days ago | 1500 views | 0 times favorited | 40 replies | ![]() |
483 days ago |
Years ago I bought a PC 7538 router (3 1/4 HP plunge model) when I was building a timber frame house. I later put a fine threaded depth adjusting knob on it and set it up in a Rockler router table. Needless to say, the router is a beast and mounting and dismounting it from the table is quite the task (and the older, undersized plate doesn’t help, as the router is too big to go though the hole in the table). So I’d like to keep the big PC set up in the table full time and am looking for a smaller router for all the typical hand held work (edge treatment, flush trimming, etc….) But…............. I’d also like to take a crack at dovetails cut with a router jig some day. I’d like to avoid getting both a 2 HP router and a trim router if I can…. and am wondering, can the Dewalt DWP 611 can do all of my and held work? Or will I be condemned to buying a 2 HP router for dovetails? If this little puppy is up to the task, is the kit with the plunge base worth an extra $65? I don’t see myself doing any inlay work…. but I’m thinking that having the handles may make the difference working the router on a dovetail jig. Thanks for any words of wisdom…. -- Matt, Pine is fine, but Oak's no joke! |
40 replies so far
#1 posted 483 days ago |
It starts with a second router, then before you know it, you have 39… I had the same dilemma. Got the 3HP in the table and a PC690 on the bench -- "Hard work is not defined by the difficulty of the task as much as a person's desire to perform it.", DS251 |
#2 posted 483 days ago |
PS… I’ve used the Grizzly trim router at work and for $45 it seems like I couldn’t go wrong picking it up to complement a nice multi-base 2 HP unit … but the depth setting on the Grizzly is pretty week, and you have to make multiple adjustments if you want to hit the point of tangency spot on with a round over bit. Also for consideration…. ALL of my bits are 1/2” shank… So if I punt the 2 HP router and try to get the job done with the DWP611… I’m going to have to put some money into tooling again. -- Matt, Pine is fine, but Oak's no joke! |
#3 posted 483 days ago |
From my perspective several routers are necessary. I have a PC7518 for heavy work such as panel raising in my router table and a Bosch 1617 for the lighter work in the router table. I looked at the Dewalt 611 and it is not capable of using 1/2” bits but is great for handheld work. Routers are like potato chips…you can’t have just one. I am up to 8 or 9 routers now and most are 2.25hp models. Probable a few more than I need but I keep certain bits in certain routers for frequent tasks. -- Every step of any project should be considered your masterpiece if you want the finished product to reflect the quality of your work. http://www.FineArtBoxes.com |
#4 posted 483 days ago |
The good dovetail jigs come with 1/2” shank bits. Those won’t fit in the trim router. Neither will your existing bits. I have a table router, handheld router, and a laminate trimmer. I can tell you I never use the trimmer for dovetails. -- Willie, Washington "If You Choose Not To Decide, You Still Have Made a Choice" - Rush |
#5 posted 483 days ago |
Dunno about the DW, but I grabbed the Hitachi M12VC specifically for dovetails…it’s quiet, light, precise, well balanced, well made, has variable speed, plenty of power for the task, accepts 1/2” shanks, and accepts standard 1-3/16” bushings without an adapter. It’s also usually a nice bargain (currently $109 shipped from Amazon). I kept this one over some other really nice 2hp routers because it was lighter, which is handy for dovetails. You’ll love having a 2nd router…. I’m managing fine without a trim router, so you might make it without a third! -- Happiness is like wetting your pants...everyone can see it, but only you can feel the warmth.... |
#6 posted 483 days ago |
before you know it, you have 39 that’s exaclty what I’m hoping to avoid? I’m already maxing out my limited storage space with seven different flavors of drills :^( (and still no hole hawg) -- Matt, Pine is fine, but Oak's no joke! |
#7 posted 483 days ago |
Well…I have several routers. I definately see the need, one for dovetails, one for my dado jig, I have three Harbor Freight routers that I bought for about 17 dollars each. I keep a roundover bit in one, a small flush trim bit in another and a chamfer bit in the third. For small work, they are great. I grab one, adjust it and go. The best part is that I don’t use them enough to really wear them out. I have had them for over two years! This isn’t anything i would suggest for the production shop, but for hobbiests, it is great. I find that I one big router in the table, one for general purpose, one for my dado jig, one for my dovetails and the three HF routers work fine. re, I am a power tool adict. There, I said it. Now give me a cup of coffee and move on to the next guy in the circle… -- When you earnestly believe you can compensate for a lack of skill by doubling your efforts, there is no end to what you CAN'T do |
#8 posted 483 days ago |
The good dovetail jigs come with 1/2” shank bits. that info. may tip the scale… are you able to operate the lighter 2 HP fixed base routers with one hand? I’m a little taken aback by how much the upcharge is to get a two base kit…. Not sure I really can justify the expense to get a plunge base, especially when I have the beast…. -- Matt, Pine is fine, but Oak's no joke! |
#9 posted 483 days ago |
I am a power tool adict. There, I said it. Now give me a cup of coffee and move on to the next guy in the circle… somehow I gather that you’re not really looking for a cure :^) -- Matt, Pine is fine, but Oak's no joke! |
#10 posted 483 days ago |
My dad has a DeWalt plunge router that works great for hand held work. The majority of what we do aside from that is all on the Delta 3hp shaper table. It’s a monster, and we use the heck out of it for raised panels. I would go with something more substantial than a 1 1/4 horse router. Our DeWalt 2 horse is plenty light for handheld work. But that’s just my opinion, you may want to go to a store to compare weights, wave the routers around for a bit, make sure you can handle them first. -- Laywer by day, Carpenter by later in the day. |
#11 posted 482 days ago |
...are you able to operate the lighter 2 HP fixed base routers with one hand? The Milwaukee 5615 and 5616 have the BodyGrip feature that allows one handed operation with good control. A D-handle also allows for one handed use, but I don’t know if it provides as much control. Those routers are also excellent choices, but are heavier and generally more expensive than the Hitachi. Reaper’s advice to handle the routers is excellent. -- Happiness is like wetting your pants...everyone can see it, but only you can feel the warmth.... |
#12 posted 482 days ago |
1-1/4 porter cable is my favorite for dovetailing and all free hand stuff. Just heavy enough to be stable but light enough to use all day long. and it will surprise you at just how much you can load it up. -- If the old masters had power tools, they would have used them. So get off your damn High Horse. |
#13 posted 482 days ago |
I’ve read lots of comments on this site recently about routers. I sense a theme. People want lighter, easier to handle routers for hand held work and they are finding that the lower horsepower units are adequate for most tasks. In my case, I have one heavy duty (over 3 hp) router that I virtually never use. I have 3 that are mid-range (2.25 hp) including the one permanently mounted in my table. Most recently, I picked up a Hitachi M 12 VC (1.75 hp). Each has a different feel and personality and I like them all. The mid-range machines have been my standard and I like having more than one because I can set up 2 routers with 2 different bits and/or bit depths and minimize bit changes when work on a project that requires multiple router settings. One of the disadvantages of routers is that once you remove a bit you have no way (that I know of) to repeat the exact setting you had previously. That is why so many of us have multiple routers. As an FYI, my new Hitachi was purchased to be a dedicated dovetail router, but I have been trying it in other applications and I like it. I don’t notice a difference between its power and the power of the mid-sized routers I have. -- Rich, Cedar Rapids, IA - I'm a woodworker. I don't create beauty, I reveal it. |
#14 posted 482 days ago |
Thanks for all the replies guys…. Have any of you, who are using the Hitachi, having problems with 1/2” bits slipping? And did yours come with a square collet nut? Amazon has the 1.25 HP Dewalt (without the plunge base) on sale for $114, and I’m very tempted. But the Hitachi (without the plunge base) is also inexpensive at $110 I’ve accumulated some nice tools over the years…. mainly because I’ve spent my money carefully and have researched each decision in an effort to get the “right” tool and avoid redundancy. The other half of this router decision is whether or not I should get a kit with a plunge router. My beastly PC can plunge if I really need that ability. And I really don’t have any plans to do inlay work… Hmmmm…. decisions.. decisions… -- Matt, Pine is fine, but Oak's no joke! |
#15 posted 482 days ago |
I’m certainly no expert, but …. 1) My Bosch 1617EVSPK is smooth, powerful, feels exceptionally comfortable for hand-held work, and was reasonably priced. I see a LOT of favorable reviews for the 1617, written by much more experienced folks; 2) My wife and I talk about this. Turns out, she can only wear one pair of shoes at a time, but … that hasn’t stopped her from …. ;-) I feel safe in saying that … the inveterate router-junkies around here … in the early days … were pretty sure THEY had it under control, too. Tools happen. -- -- Neil |
| Forum | Topics |
Woodworking Skill Share
8794 |
Woodturning
223 |
Woodcarving
28 |
Scrollsawing
61 |
Joinery
81 |
Finishing
1534 |
3551 |
15789 |
Hand Tools
2037 |
Jigs & Fixtures
495 |
Wood & Lumber
2841 |
809 |
Focus on the Workspace
902 |
766 |
Woodworking Trade & Swap
2740 |
LumberJocks.com Site Feedback
1547 |
Coffee Lounge
6162 |
