Disston saw identification
« back to Hand Tools forum
Forum topic by Tokolosi posted 01-26-2012 06:19 PM 7143 views 0 times favorited 5 replies Add to Favorites Watch
View Tokolosi's profile
Tokolosi
678 posts in 2594 days
01-26-2012 06:19 PM
I recently was given a disston handsaw. I am really struggling to positively identify the model type. I want to restore it but want to know everything about it before I even touch it. If any of you can help I will be so greatfull. It has a 20” blade.
-- “There is nothing like looking, if you want to find something. You certainly usually find something, if you look, but it is not always quite the something you were after.” ~ JRR Tolkien
5 replies so far
View hairy's profile
hairy
2783 posts in 3771 days
#1 posted 01-26-2012 08:05 PM
http://www.disstonianinstitute.com/index.html
-- My reality check bounced...
View Arminius's profile
Arminius
304 posts in 4042 days
#2 posted 01-26-2012 08:54 PM
From the handle type, it is post-war, maybe in the 53-55 time period, but I suspect probably just after that. the medallion is the very last pattern used before HKPorter took over, however it was used for a few years after. You probably won’t find this saw on the Disstonian Institute site, indicating that it was one of the new line that was introduced, more cheaply made (handle is a simple oval cutout, etc.) and less interesting as either a collector’s item or a user.
As such, I would not worry too much about restoring it – but if this is your first rehab project, a good one to learn on.
Tokolosi
#3 posted 01-26-2012 11:06 PM
@ Hairy; Thanks for that link. Very helpfull.
@Arminius; I think you are right. Based on all the info I have got that fits. Thank you for the great resonse! And yes, this was going to be a practise run for the EC Atkins “The Five Hundred” that I also got.
View chrisstef's profile
chrisstef
17800 posts in 3245 days
#4 posted 01-26-2012 11:18 PM
Ive done a few saw rehabs and i found out the hard way that if you soak papertowels in evaporust and let it evaporate the paper towel does not come off the saw well. Figured id throw that one out there so you avoid a sticky mess that i had.
I liked the mineral spirits and sandpaper method of rust removal on the old saws. Just go real easy around the etching if there is any.
Tokolosi
#5 posted 01-27-2012 12:04 AM
Thanks chrisstef. Good tip. I will take that into account.
