what's the thinest size for a planer?
Forum topic by KenBry posted 478 days ago 848 views 0 times favorited 21 replies Add to Favorites Watch
View KenBry's profile
KenBry
449 posts in 612 days
478 days ago
I have been shopping for planers and was wondering what’s the thinest stock you can feed through the average planer? 1/2” 1/4” 1/8” ....???
-- Ken, USAF MSgt, Ret.
21 replies so far
View DS's profile
DS
1816 posts in 585 days
#1 posted 478 days ago
My 12-1/2” planer says no less than 1/4” thickness.
There are ways around this though. A sled, for example.
View TheDane's profile
TheDane
2672 posts in 1828 days
#2 posted 478 days ago
I have a DW733 … can’t go further than a 1/4” without a sled. With a sled, I have gone down to 1/8”.
—Gerry
View ChuckC's profile
ChuckC
547 posts in 1100 days
#3 posted 478 days ago
I have a Dewalt 735 and I routinely go down to 1/8” without a sled.
View Gene Howe's profile
Gene Howe
3176 posts in 1593 days
#4 posted 478 days ago
My little Delta 13” lunch box will plane 1/8 without a problem. Even so, I use a sled.
View dbhost's profile
dbhost
4748 posts in 1397 days
#5 posted 478 days ago
My Ryobi says 1/4”, I have planed down to 1/8” with a sled. Don’t want to go any thinner…
View usnret's profile
usnret
185 posts in 673 days
#6 posted 478 days ago
I have a Delta 12 1/2” planer, older model, and with a false bed made out of MDF I have planed red oak to 1/16”.
-- Chief Petty Officer USN(RET) 1991-2011
View lew's profile
lew
8970 posts in 1920 days
#7 posted 478 days ago
Once you get thinner than 1/8”, with or without a sled, you run the risk of the stock shattering. This is especially true of brittle wood (walnut) and any wood that has “wild” grain or defects of any type.
Just my 2ยข
Lew
-- Lew- Time traveler. Purveyor of the world's finest custom rolling pins!
View Charles Maxwell's profile
Charles Maxwell
824 posts in 1972 days
#8 posted 478 days ago
1/8” for dewalt 735
-- Max the "night janitor" at www.hardwoodclocks.com
View William's profile
William
7056 posts in 1007 days
#9 posted 478 days ago
Most only go to a quarter.
I have went down as far as a sixteenth with a sled.
The thing about going thinner than a quarter though is, like someone else said, the potential of the stock shattering and slinging pieces everywhere.
The only way to reduce the risk of it is to make sure your blades are very sharp and take a minimal amount on each pass, especially once you get thinner than a quarter.
By the way, as my luck would have it, everytime I’ve had a piece shatter on me, it also chipped my blade.
View HorizontalMike's profile
HorizontalMike
4906 posts in 1079 days
#10 posted 478 days ago
I have planed 0.19in. This was hardwood (ash) on my 13in Ridgid Planer.
View gfadvm's profile
gfadvm
6600 posts in 855 days
#11 posted 478 days ago
7/64 ths with my Ridgid 3 blade planer
View richgreer's profile
richgreer
4474 posts in 1239 days
#12 posted 478 days ago
ditto on what both Gerry (The Dane) and Lew said.
If I need to get below 1/4” I use my drum sander. Note – with the drum sander I can comfortably remove about 1/200” per pass so it takes a lot of passes to remove stock. It is not a good idea to push a drum sander to take more with a pass. FYI – that is about 1/6 of a revolution on the adjustment wheel per pass.
View Raymond's profile
Raymond
665 posts in 1892 days
#13 posted 478 days ago
I have planned to less than a 1/16 with my 13” Ryobi, I use double sided tape and stick the piece i want planned thin to another thicker piece and take very thin passes. Then use a scraper seperate the thin piece from the thick piece, a little solvent to remove the tape and there you go.
-- Ray
View Sawdust4Blood's profile
Sawdust4Blood
321 posts in 1186 days
#14 posted 478 days ago
Dewalt 734 down to 1/8” maple. That was as thin as I was comfortable going without worrying about shattering.
-- Greg, Severn MD
View ajosephg's profile
ajosephg
1718 posts in 1726 days
#15 posted 478 days ago
What Lew and Rich said. If the stock explodes you better be wearing body armor over your vital parts
-- Joe
