bending pylwood
Forum topic by baby86bear posted 01-25-2012 08:13 PM 1972 views 2 times favorited 11 replies Add to Favorites Watch
View baby86bear's profile
baby86bear
15 posts in 2331 days
01-25-2012 08:13 PM
I have a Dr. Seuss style bookcase that i have been asked to make for a friends daughter. i have cut the front and back out with the shelves. but, here is the issue, i cant get the curves of sides to look right. i have used laminate strips, no good!! thin plywood but, it has the ability to crack.
if there is anyone in the lumberjock world that can help, PLEASE!!!!!!!!!!!
11 replies so far
View Howie's profile
Howie
2656 posts in 2920 days
#1 posted 01-25-2012 08:35 PM
Cut notches in the back of the PW. How tight of a radius are you trying to bend and what size PW?
-- Life is good.
View Grandpa's profile
Grandpa
3259 posts in 2672 days
#2 posted 01-25-2012 09:32 PM
They do make bendable plywood. It just flexes when handled
View Loren's profile
10384 posts in 3645 days
#3 posted 01-25-2012 09:50 PM
You can get the Italian bending poplar and laminate it to hold the
bend. You can also get 3/8” thick “wiggle wood” which bends
in one direction quite a lot. Fastened to a frame with the curve,
the wiggle wood will seem quite solid.
View rcs47's profile
rcs47
190 posts in 3126 days
#4 posted 01-26-2012 12:22 AM
Here is a site that carries different bending plywoods.
I have not used these people. I found them when searching for bending plywood because I’ve been thinking about making a cyclone.
Good luck,
-- Doug - As my Dad taught me, you're not a cabinet maker until you can hide your mistakes.
View jim C's profile
jim C
1472 posts in 3095 days
#5 posted 01-26-2012 12:30 AM
Rick L
How do those sites help in this thread?????
View Dan Lyke's profile
Dan Lyke
1520 posts in 4122 days
#6 posted 01-26-2012 01:37 AM
I’ve heard, but haven’t tried, that you can also take one face off of ¼” 3 ply plywood to get a reasonable bendy ply, do that with a few pieces and laminate ‘em together?
(I have cut slits along the back of a piece of ply to bend it, and that’s worked fairly well when the back is completely hidden.)
View William's profile
William
9949 posts in 2839 days
#7 posted 01-26-2012 03:04 AM
I’m curious how tight a radius you’re having to bend. I have made boat themed shelves using quarter inch plywood with no problems.
Another option is to cut shallow kerf cuts along the inside of the curved plywood. This allows it to bend around tight radiuses without cracking.
View cobb769's profile
cobb769
30 posts in 2086 days
#8 posted 10-22-2013 03:19 PM
BabyBear, How did your bookshelves turn out? I’m making a set right now and decided to go with 1.5” pine strips on the sides. I nailed them into the front frame and back. Mine will be painted, but after a little wood filler and sanding, they look amazing. The solid pine also added a lot of stability.
-- Patrick "Pacman" Cobb, North Carolina
cobb769
#9 posted 10-22-2013 03:20 PM
Here is an unfinished picture of my bookshelf, but you can see how the pine strips work for the sides.
117091 posts in 3574 days
#10 posted 10-22-2013 03:32 PM
Cool design nice work.
cobb769
#11 posted 10-22-2013 05:46 PM
Thanks Jim. I’ll add this full project next week once I’m complete with the trio. You can see the smaller two in the background (less their sides). I experimented around with some bendi plywood and laminate, but was ultimately very satisfied with the strip sides.
