| Forum topic by JetJock | posted 45 days ago | 71 views | 0 times favorited | 2 replies | ![]() |
45 days ago |
Hello everyone, Recently, I was lucky enough to pick up a Delta sanding unit (9” disk w/6” wide belt). The guy gave me the sanding machine because he wanted to make room in his shop for his new Harley (win win situation). The only problem with the machine is that it has a fine coating of Poly on the entire machine. This guy did a fair amount of spraying his finished pieces, and unfortunately, the overspray found its way to the sanding machine. I’d like to remove all the Poly without damaging the painted surface. I’m not sure if this is possible, but I thought I would post to see if anyone has had any experience in doing this. Thanks for the help. -- Todd C, Central Illinois |
