Red White and Blue inlay ideas needed.
Forum topic by Speednork posted 01-24-2012 05:56 PM 973 views 0 times favorited 2 replies Add to Favorites Watch
View Speednork's profile
Speednork
65 posts in 3299 days
01-24-2012 05:56 PM
Topic tags/keywords: question inlay
I have commissioned a piece of furniture that requires Red White and Blue accents. I am looking for a source for acrylic or some type of poly inlays or banding. Is there any type of liquid fill you can use that is solid colors that you can fill router designs, sand and finish? What accents I use are up to me so I am open to ideas. I just need to keep it subtle.
-- In the time it takes some people to plan a project they could have built the project. Work from within not from paper.
2 replies so far
16272 posts in 4124 days
#1 posted 01-24-2012 06:36 PM
You can color fiberglass resin with dye, and use that to fill router-cut designs. It’s pretty sloppy, but the excess can be sanded away for a good result.
View KnickKnack's profile
KnickKnack
1088 posts in 3472 days
#2 posted 01-24-2012 06:51 PM
I’ve been playing around with a similar idea recently (see my latest, terrible but “proof of concept” project). The “problem” comes with the colouring material running along the grain. If it does that you cannot sand it down. Dense woods suffer less, or colouring material that’s “thick” – water-based is difficult. Hammerite is good and, although I have yet to try it, I think oil paints would work well – cheap “try it out” sets are available everywhere.
-- "Do not speak – unless it improves on silence." --- "Following the rules and protecting the regulations is binding oneself without rope."
