Powermatic 1632 Open Ended Sander Tracking Problems
Forum topic by darren665 posted 01-24-2012 04:41 PM 1471 views 0 times favorited 3 replies Add to Favorites Watch
View darren665's profile
darren665
13 posts in 2186 days
01-24-2012 04:41 PM
Hi, does anyone out there have a Powermatic 1632 thickness sander that has the belt coming completely off all the time?
I have spent 3 hours trying to get it to work but have given up…
Thanks,
Darren665
-- Darren,Victoria,http://www.bertuccio.ca
3 replies so far
View twiceisnice's profile
twiceisnice
95 posts in 2698 days
#1 posted 01-25-2012 03:39 AM
SANDING BELT TRACKING & OSCILLATION
The tracking and oscillation of your sander are pre- adjusted at the factory. However, should adjustment be required, do the following:
1. Adjust the air valve (A), Figure 3, to control the tracking sensitivity.
2. The oscillation speed can be controlled by adjusting the top air valve (B).
3. Empty the glass container© as needed.
Go to powermatic to look at manual. I cant copy the pic.
twiceisnice
#2 posted 01-25-2012 03:40 AM
Type in your model no.
darren665
#3 posted 01-25-2012 04:36 PM
Thanks for that, yes I saw the steps that you are mentioning in the manual and I still could not get it to go, or at least I am not interpreting the manual correctly. I think I will try and get someone at Powermatic to talk me through it. Appreciate your input.
Darren
