| Forum topic by Brett | posted 487 days ago | 998 views | 0 times favorited | 7 replies | ![]() |
487 days ago |
My wife has a kitchen tool that needs a new handle. I can use a 3/4” dowel for the handle, but I need to drill a hole for a screw into the center of each end of the dowel. What kinds of wood will hold a screw drilled right into end grain? Also, what finish should I use on the handle? Can wood stand up to being washed with a soapy sponge every once in a while? -- More tools, fewer machines. |
7 replies so far
#1 posted 487 days ago |
End grain just isn’t known for having exceptional screw-holding power. That being said, a fairly dense, fine-grained wood such as maple would perform better than something soft like poplar. You’d want to pre-drill the wood first to prevent splitting though. I would recommend finding some way to use a stainless steel machine screw and nut instead if at all possible. Finish might depend upon the tool in question. I’ve seen wooden spoons last for years with no finish at all. They need to be allowed to dry well out after washing. -- See my work at http://remmertstudios.com and http://altaredesign.com |
#2 posted 487 days ago |
Check McFeely’s for screws made for end grain and soft wood use. They’re typically coarse thread. We have several wooden spoons that have no finish. They get hand washed (never in the dishwasher) and air dried. They are never “soaked” in water. -- Adversity doesn't build character...................it reveals it. |
#3 posted 487 days ago |
Drill and install a cross-dowel to hole the screw. |
#4 posted 487 days ago |
When screwing into end grain you can sometimes drill a hole (or several) into the face and plug it with a dowel. When you then screw into the end grain you end up hitting the dowel along its grain for a tighter fit. In this instance you can drill a through hole 3/4” or so from each end of the dowel (handle) and fill it with the appropriate size dowel. Then, drill pilot holes into the ends of the handle, through the other dowels, and fasten the screws. Some may like the design element of the extra dowels too?? |
#5 posted 487 days ago |
Can you drill a hole for a cross dowell? If so, you put a 3/8 dowell, for instance, through the 3/4” rod about an inch from the end. Then the screw hole is drilled in the end and through the cross dowell. When you put the screw in it bites into the cross dowell and locks into it. I have used this method many times. works great. And, I think it looks good too. Especially with a darker wood for the cross dowell. Well dang. Lets just all get on the band wagon. There was only 2 replys when I started writing this. -- Michael :-{| Diapers and politicians both need to be changed often; and for the same reason. |
#6 posted 486 days ago |
E-Z Loc and other manufacturers make metal inserts that have a heavy wood screw thread on the outside, -- As ever, Gus-the 74 yr young apprentice carpenter |
#7 posted 486 days ago |
Thanks for the suggestions. :) -- More tools, fewer machines. |
| Forum | Topics |
Woodworking Skill Share
8798 |
Woodturning
224 |
Woodcarving
28 |
Scrollsawing
61 |
Joinery
82 |
Finishing
1537 |
3554 |
15806 |
Hand Tools
2039 |
Jigs & Fixtures
496 |
Wood & Lumber
2846 |
810 |
Focus on the Workspace
903 |
766 |
Woodworking Trade & Swap
2741 |
LumberJocks.com Site Feedback
1547 |
Coffee Lounge
6165 |
