Suggestions???
Forum topic by jjraybur posted 01-24-2012 04:37 AM 1046 views 0 times favorited 4 replies Add to Favorites Watch
View jjraybur's profile
jjraybur
56 posts in 3577 days
01-24-2012 04:37 AM
Topic tags/keywords: trick
So I thought I would finish this top today, however when you keep doing stupid things, it takes longer than it should. Anyway, after I routed an edge around the entire top, instead of leaving the back alone, my top was too short for the table it’s going on. Then I decided to rip off the routed edge on the back, and replace it with another strip of cherry. No problem. Once the glue up was dry, I sanded it and took the router back out. This time I forgot to flip the top over, so when I went to route the sides of the edge on the newly attached piece, there was nothing for the bearing to catch, and I hogged out a nice round piece of my not nearly completed table top. Any suggestions on what to do to fix this without it being terribly apparent??
-- Jeremy, Baton Rouge, LA - rayburnfinefurniture.com
View cabs4less's profile
cabs4less
235 posts in 2996 days
#1 posted 01-24-2012 05:36 AM
I dont know what your design is but any way you can incorporate bread board ends its all I can think of
-- As Best I Can
View RandyM68's profile
RandyM68
693 posts in 2552 days
#2 posted 01-24-2012 06:11 AM
Do that a bunch more times, and say you wanted a scalloped edge. Seriously, the only thing I can think of, since you already scabbed a piece across the back, do the same to the other three edges. It may not look quite right, but at least it will look like you did it on purpose.
-- I can explain it to you, but I can't understand it for you. I'm sorry,thanks.
View SnowyRiver's profile
SnowyRiver
51457 posts in 3714 days
#3 posted 01-24-2012 06:21 AM
I think I would rip the damaged piece out and glue in a new board the length of the top and route the edges again. You could make the replacement board with enough width to replace the cherry edge too.
-- Wayne - Plymouth MN
View doordude's profile
doordude
1085 posts in 3217 days
#4 posted 01-24-2012 08:55 AM
rip it down by 2 inches, and reroute the detail. hard to cross cut and glue on another piece, and hide the cut line
