Another workbench question....
Forum topic by BerBer5985 posted 01-23-2012 11:37 PM 1762 views 0 times favorited 14 replies Add to Favorites Watch
View BerBer5985's profile
BerBer5985
445 posts in 2389 days
01-23-2012 11:37 PM
I have most of the materials ready for my workbench, but I had two questions really:
1) I wanted to use 6×6’s for the legs for weight and not having to do laminations, but all I can find is 6×6’s in treated wood. Would it be bad to use treated lumber for the legs of the workbench, especially when I have a leg vise with a wood screw, or should I just do the glue ups?
2) I’m going to put a twin screw end vise on and I’ll need an end cap. I see different ways that people attach them, but what seems to be the best practice that can be obtained with hand tools? In other words, I know there are concerns of expansion and contraction and what not, but workbench builds I’ve seen seem to skip over this part of the install for whatever reason. Maybe I’m making more out of it than what it is. Should I build the workbench top, then dovetail the ends of the last two pieces of the top lamination and the end piece and then glue them up to the top, and then install my legs flush with that?
-- Greg, Owner, Quality Carpet One, www.qualitycarpetonecrofton.com
14 replies so far
View TheDane's profile
TheDane
5404 posts in 3631 days
#1 posted 01-23-2012 11:40 PM
Fellow LJ mvflaim used treated posts for legs on his bench … check out his 3-year update: http://lumberjocks.com/mvflaim/blog/27701
Can’t help on the second question.
—Gerry
View Brandon's profile
Brandon
4152 posts in 2920 days
#2 posted 01-23-2012 11:42 PM
Regarding the legs, just go with laminated wood. For starters, you want to avoid the PT stuff if possible. Second, it will look a bit differently from the rest of your bench and typically that stuff is wetter even if it is kiln dried.
I laminated my legs and for me the biggest issue is usually aligning them. You can always use dowels to help with a proper alignment.
-- "hold fast to that which is good"
View Bill White's profile
Bill White
4907 posts in 3929 days
#3 posted 01-24-2012 12:04 AM
No PT stuff at all. You’re askin’ for splitting and wierd chemical reaction. I found some white oak rough sawn that I was able to dress to 3 1/2” squares for the legs. Stretchers were morticed into the legs, and a shelf was added. My top is a bowling alley. 15+ years old. Still solid. I used 3/4” Maple for the faces on the top to trim out the alley pieces, and recessed the vices (face and end) into the faces.
Bill
-- bill@magraphics.us
BerBer5985
#4 posted 01-24-2012 12:10 AM
How about douglas fir 4×4’s? I have those? Are those going to be substantial enough? I bought those for the top to be laminated using about 7, but I bought a few extras.
View Mauricio's profile
Mauricio
7144 posts in 3120 days
#5 posted 01-24-2012 06:30 AM
Look around for SYP that is not pressure treaded. If your lumberyard doesn’t have it ask them to refer you to place that does. Its out there.
Why would you want to work with toxic material? That’s not fun, I would be to paranoid about the dues and generally having so much contact with it.
BerBer5985
#6 posted 01-24-2012 06:51 AM
SYP in Maryland is very scarce. I have looked all over and it’s not readily available here. Douglas for is about the best option.
View doordude's profile
doordude
1085 posts in 2951 days
#7 posted 01-24-2012 08:49 AM
verticle grain doug fir would be great. don’t use framing doug fir. what’s your 4×4 made of ?
what about gluing up pieces to get to the size you want. i used LVL on my legs and i didn’t like working with the splintering. i used 4×6’s and ended up, ripping them down and gluing maple back on. look for an inexpensive hard wood to use. you’ll be happy’er in the long run. these benches, if done right, will last for several generations. with a budget in mind also. i have tips to your second question if you wish.
BerBer5985
#8 posted 01-24-2012 04:11 PM
I’d love some tips on the breadboard end too. The lumber I have are very straight grained Doug fir 4×4 with very few knots and most of the boards are dead straight. I think they’ll make a good thick and heavy top. At least I hope. I bought some 2×12s as well in hem fir that I was thinking about for the legs. I was going to rip them down make the legs but I’m still toying with ideas.
TheDane
#9 posted 01-24-2012 05:07 PM
Greg—The legs on my bench are laminated Douglas Fir … a 1” x 4” sandwiched between a pair of 1 1/2” x 4”.
I used through tenons and pegged them (3/8” oak dowels) ... never been a problem with stability.
—Gerry
View dannelson's profile
dannelson
193 posts in 2339 days
#10 posted 01-24-2012 05:37 PM
my advice would be to build a modest bench first and work with it. go cheap, execpt for the vices. look for used material. laminate the legs or box beam them.as greg said.I really get a kick out of my fellow woodworkers that build these beautiful benches but than cover them with mdf for protection. yes there is the prestige of a nice bench and we all want one . build what works for you and than refine it to your liking in a couple of years. I still have my plywood torsion box bench, wrapped with a hardwood apron and two vices . pullout storage underneth. I can run a screw in the top anywhere for fancy hold downs and not cry. seems that there are alot more places in the shop to spend money than on a bench.
-- nelson woodcrafters
BerBer5985
#11 posted 01-24-2012 07:06 PM
Exactly my thoughts too.^^ I’d love to have a $3000 bench made of exotic hardwoods or something, but I am keeping in mind that I will be working on this bench. I already bought the materials, it’s just a matter of how stout to make the legs and I think 4×4’s from what people are saying ought to be sturdy enough. I don’t want to spend a lot of money on the wood because this will be a learning project for me too. So I’m sure I’ll have some screw ups and messing up a $40 piece of maple or $12 piece of Doug Fir, I’d choose the fir.
I’m still looking for some instruction on the breadboard end however. Probably the most expensive part of the bench so far is the wood vise screw kit which I’m excited to receive!
Mauricio
#12 posted 01-24-2012 07:09 PM
Douglas Fir is really nice wood. You will be happy with it. In Georgia is expensive so not really an option.
TheDane
#13 posted 01-24-2012 07:30 PM
Greg—I don’t about other stores, but at my local Menards, the 2×10’s and 2×12’s are all kiln-dried Douglas Fir. I buy the 2×12’s and rip/joint/plane them to size. I got my whole benchtop out of 3 – 12 foot 2×12’s.
Click for details
—Gerry
View MrRon's profile
MrRon
4720 posts in 3212 days
#14 posted 01-26-2012 08:42 PM
Four 2×4’s glued up short side to long side will form a nice 5”x5” square leg.
