Sharpening circular saw blade with hand tool
Forum topic by alex posted 01-23-2012 07:26 PM 3174 views 0 times favorited 6 replies Add to Favorites Watch
View alex's profile
alex
17 posts in 2482 days
01-23-2012 07:26 PM
Hi all,
is it possible to Sharpen circular saw blade with hand tool ?
how to proceed ?
regards
Alex
View Loren's profile
9760 posts in 3518 days
#1 posted 01-23-2012 07:30 PM
Yes, you can sharpen steel blades by hand. A circular saw vise
makes the process easier. Sears used to sell them.
If you have carbide tipped blades you need special power
tools to do a good job.
View alex's profile
alex
#2 posted 01-23-2012 08:58 PM
thanks,
in fact i have only classic seel blade
i do the job with straight sharpening file ?
alex
#3 posted 01-23-2012 09:25 PM
After several sharpenings you’ll have to joint the outside
edge, set the teeth and recut the gullets perhaps, but
if you are making only cuts where the top of the saw
protruded through the board (e.g. not making grooves)
simply refiling the teeth to be pointed with whatever file
you have should improve your cutting results.
I suppose many texts on woodworking published prior
to the 1970s have instructions on sharpening steel blades.
View alex's profile
alex
#4 posted 01-23-2012 09:29 PM
thanks a lot :)
View Bill White's profile
Bill White
4819 posts in 3831 days
#5 posted 01-23-2012 10:35 PM
Alex mon ami, “discretion is the better part of valor”. Circular saw blade sharpening is best left to professionals.
Bill
-- bill@magraphics.us
View alex's profile
alex
#6 posted 01-24-2012 09:19 PM
hi bill,
you ‘re right, but got some old blade and i want to try it
Alex
