Router Bits
Forum topic by Warren posted 01-23-2012 03:00 PM 989 views 0 times favorited 8 replies Add to Favorites Watch
View Warren's profile
81 posts in 2268 days
01-23-2012 03:00 PM
Topic tags/keywords: question router
Whats the best way to clean router bits. Mine have a black resin buildup on them.
-- Warren, Cambridge,OH.
8 replies so far
View woodman88's profile
143 posts in 2581 days
#1 posted 01-23-2012 03:25 PM
I use Simple Green with a brass brush It works good for me
16273 posts in 4150 days
#2 posted 01-23-2012 03:31 PM
Ditto woodman88.
View saddletramp's profile
1180 posts in 2570 days
#3 posted 01-23-2012 03:44 PM
Let them soak in simple green then go really easy with the brass brush or better yet, use an old tooth brush.
-- ♫♪♪♫♫ Saddletramp, saddletramp, I'm as free as the breeze and I ride where I please, saddletramp ♪♪♪♫♪ ...... Bob W....NW Michigan (Traverse City area)
#4 posted 01-23-2012 03:46 PM
Thanks Ya’ll :) Someone told me to use oven cleaner on them an let them soak and just wipe off but wasnt totally sure
View devann's profile
2246 posts in 2625 days
#5 posted 01-23-2012 05:14 PM
It depends on weather they have bearings or not. If it has bearings I clean it by hand, scraping the cutters with a razor blade. I don’t want to be soaking the bearing in anything that may compromise the lubrication.
I’ve used oven cleaner on my large saw blades for many years without a problem. There’s just not that much to clean on a router bit. After cleaning blades or bits I like to use a carbide lubricate so the cutters run cooler and slow down the pitch buildup.
Rick Dennington
5742 posts in 3126 days
#6 posted 01-23-2012 05:56 PM
For years I’ve used the Rockler Tablesaw and Router bit kit….It consist of a larger blue “tub” with a lid and a riser in the middle to hold the blade off the bottom to get to it better…...also has a small plastic jar for cleaning router bits (just be sure to remove the bearings before soaking).,and it comes with a quart of pitch cleaner and a little brass wire brush … can use it full strength, or dialute it some….It woks good, and is not as messy as some cleaners….About $25-30 bucks from Rockler….the cleaner last a long time, too, cause you can use it over and over several times on several blades…when finished, just put the lid on and forget it….
View dbhost's profile
5687 posts in 3164 days
#7 posted 01-23-2012 06:03 PM
Another vote for the Rockler bit and blade cleaner kit. When it goes on sale, it’s as cheap as a comparable quantity of Simple Green, and you don’t have to worry about it trashing your brazing…
-- My workshop blog can be found at, YouTube Channel
View gfadvm's profile
14940 posts in 2622 days
#8 posted 01-24-2012 05:48 AM
I have soaked my router bits in bug and tar remover in a small jar overnight. I have been doing this for years and never harmed a bearing. I use a brass brush for bad crud but usaally everything wipes off with a rag. I soak all the bits I used that day every day and that way they never get really cruddy. Keeping them that clean seems to make them last longer? Less heat build up?
