Changing tablesaw blade
Forum topic by Traildog posted 01-23-2012 03:22 AM 1840 views 0 times favorited 12 replies Add to Favorites Watch
View Traildog's profile
Traildog
4 posts in 2221 days
01-23-2012 03:22 AM
I do not have the wrenches that came with my tablesaw. Can i use another type of wrench to change the saw blade?
12 replies so far
View SnowyRiver's profile
SnowyRiver
51457 posts in 3383 days
#1 posted 01-23-2012 03:25 AM
Sure. You just have to be careful that you dont strip the head of the bolt, but any wrench that fits should work fine.
-- Wayne - Plymouth MN
Traildog
#2 posted 01-23-2012 02:05 PM
Thanks for the advice. I will try it.
View RandyM68's profile
RandyM68
693 posts in 2221 days
#3 posted 01-23-2012 03:10 PM
Also, the arbor is probably left hand threads so it’s natural to turn it the wrong way. I almost put a cheater pipe on one that was stuck, Then I turned it the other way and it came right off.
-- I can explain it to you, but I can't understand it for you. I'm sorry,thanks.
View richgreer's profile
richgreer
4541 posts in 2978 days
#4 posted 01-23-2012 03:19 PM
Don’t be certain that it is a left handed thread. I believe (but I am not certain) that the threads are based on which way the blade tilts. I have a saw that tilts to the left and the threads on the arbor are right handed threads.
Note that the right size wrench may be metric. My saw requires a 17 mm wrench for the right fit. You can always get close with an imperial measurement wrench but I don’t think that is a good idea, except in an emergency.
16272 posts in 4121 days
#5 posted 01-23-2012 03:23 PM
I think Rich is right. My left-tilt saw has right-hand threads.
As Wayne said, any wrench that fits will do… just make sure it is a snug fit.
View RibsBrisket4me's profile
RibsBrisket4me
1555 posts in 2408 days
#6 posted 01-23-2012 03:52 PM
I have used a Channel-Lock tool for years to change blades.
RandyM68
#7 posted 01-23-2012 03:55 PM
Actually, we’re all right. Generally, on motor shafts the nut goes against the rotation, so it will tighten itself rather than spin off. Reversing the motor for left tilt makes everything spin the opposite direction. Some old Ford trucks have left hand threaded lugs on one side ,right handed on the other. The first time I had to put a set of tires on one, I learned the hard way. At least you’re not using a 3/4” drive impact wrench. I hope.
View HorizontalMike's profile
HorizontalMike
7747 posts in 2817 days
#8 posted 01-23-2012 03:57 PM
I am thinking that if you are going to use the “normal” straight wrenches, then I would definitely want to wear gloves to protect the hands from blade nicks/cuts. Most TS wrenchs are angled to minimize this but better safe than sorry in my book.
View AlbertaJim's profile
AlbertaJim
47 posts in 2332 days
#9 posted 01-23-2012 04:10 PM
I use a 10” adjustable “crescent” wrench which does the job nicely. My old craftsman has normal right hand threads.
-- My Boss was a carpenter
View ajosephg's profile
ajosephg
1880 posts in 3464 days
#10 posted 01-23-2012 04:15 PM
And don’t over tighten it. Just snugging it up is sufficient.
-- Joe
View Grandpa's profile
Grandpa
3259 posts in 2578 days
#11 posted 01-23-2012 06:02 PM
I believe you should stand behind the saw table as you would when operating it. You hold the blade with a wood scrap and you put the wrench on the nut and pull the wrench handle toward you. This will loosen the nut since it should be designed to tighten when in use. Think of the blade pushing the nut back as it operates. Pull it toward your body to remove it. Always turn the power off or unplug the saw when working around the blade.
View Lee Barker's profile
Lee Barker
2170 posts in 2753 days
#12 posted 01-23-2012 06:02 PM
I use a stick and a wrench for removal. 3/4×1 3/4×10 inches, with a bit of a handle hewn into one end. It wedges between the blade and the throat for the loosening turn.
To remount the blade, +1 to Joe’s comment. Most folks way overtighten at this stage.
