Priming Cabinet Grade Plywood.... On one Side
Forum topic by Logan Windram posted 01-23-2012 02:05 AM 1803 views 0 times favorited 4 replies Add to Favorites Watch
View Logan Windram's profile
Logan Windram
347 posts in 2577 days
01-23-2012 02:05 AM
So i am working on a built-in for under our basement stairs, and I used Cabinet grade plywood for the carcass and was planning to just paint the interior of the box white…. So I primed the pieces and plan to paint before put it together, and there is about 1/16 of an inch cup to the parts….
So do I have to prime the outside of the parts as well??? I have never painted plywood before…. Never really had to…
I don’t work with sheet materials to often, it was hard to even find 4×8 sheets that were not warped because of the way the we’re stored at the retailers…
Thoughts?
10477 posts in 3762 days
#1 posted 01-23-2012 02:15 AM
As long as you have tools and clamps to get mildly cupped
carcase panels to assemble tightly, I see no problem with
painting one surface.
If using MDF or ply for slab doors or other unsupported panels
however it is essential to finish or laminate both sides.
Logan Windram
#2 posted 01-23-2012 02:24 AM
Loren, thank you…
I have cabinet clamps so I will be able to get the tightly assembled, and I built this with the cabinet design in mind… So I have a face frame to go on the piece and will use that for the drawer slides, like a typical cabinet…
The doors will be made out of real wood, probably a poplar since the doors will be painted white as well…. I feel much more comfortable using wood rather than sheet goods….
View TCCcabinetmaker's profile
TCCcabinetmaker
932 posts in 2469 days
#3 posted 01-23-2012 03:37 AM
IT all depends on wether or not there is a possibility of exposure to moisture. In most cases I won’t back prime a cabinet, that is unless it’s the sink base, next to the sink base or next to the dishwasher, or next to a refrigerator, or even maybe a stove, what that’s all the bases isn’t it lol.
-- The mark of a good carpenter is not how few mistakes he makes, but rather how well he fixes them.
View Brad_Nailor's profile
Brad_Nailor
2539 posts in 4072 days
#4 posted 01-23-2012 03:43 AM
Thats why I assemble my cabinets then paint them. It may be a little tougher, but things don’t move..
