| Forum topic by Havasumatt | posted 486 days ago | 724 views | 0 times favorited | 6 replies | ![]() |
486 days ago |
Topic tags/keywords: router router adjustment bosch fine adjustment Got an annoying problem. I got the Bosch 1617 combo and use the fixed base under my table. It’s a real pain to use the fine depth adjustment. For both above and below is the same, a pain. I can get maybe a half a turn or so either way and then it gets hard and I have to wiggle the motor to loosen up what ever it’s binding on. If I don’t wiggle it binds bad enough that the c-clip comes off the adjustment bolt. Anyone have problems like this? |
#1 posted 486 days ago |
You’re not wrong, I have a Freud that does the exact same thing. I wish like $%^& I could remember what I did to correct it though. Not much help I know, but maybe there’s some comfort in company. I’ll go down to the shop and have a look. Maybe it will jog this tired brain of mine. Try lubricating the motor where it slides in the base. I use white lithium grease on mine. c -- Chunk's Workshop pictures: http://spadfest.rcspads.com/thumbnails.php?album=135 |
#2 posted 486 days ago |
I strongly recommend against wet grease or oil to lubricate the router. It will attract dust and make the problem return. I would disassemble and clean the router and lubricate with dry graphite lube. -- Willie, Washington "If You Choose Not To Decide, You Still Have Made a Choice" - Rush |
#3 posted 486 days ago |
I went down to the shop and laid my hands on my router and listened to the router spirits. Here is what they said; When router starts this, what I do is remove the base from the table. My router uses a cam-lock to lock the base to the router motor. I assume the Bosch has something similar. I readjust the cam-lock so that it holds a little tighter. Over time and use, the cam loosen up so that the base doesn’t lock as tight. There is a allen head cap screw on mine that can be adjusted to adjust the tension on the cam-lock. The other thing to look for is wear marks on the router motor. Mine used to wear and would leave a slight burr on the motor. I used some 400 grit wet/dry sandpaper to polish the motor and remove the burr. This fixed my problem. After which, I give everything a through cleaning and lube the motor / router base with white lithium grease. I hope this helps… c -- Chunk's Workshop pictures: http://spadfest.rcspads.com/thumbnails.php?album=135 |
#4 posted 486 days ago |
The white lithium grease doesn’t attract dust and dirt like other greases and oils do. -- Chunk's Workshop pictures: http://spadfest.rcspads.com/thumbnails.php?album=135 |
#5 posted 486 days ago |
Heck that was quick! Thanks fellas! I do swap from table to plunge alot and have notice some scratches that probably induced some burs. I’ll check more closely when I get back in. Someday I’ll get a nice lift system with a seperate motor just for the table. Appreciate the help as always! |
#6 posted 486 days ago |
i use slip it for things like that. -- IF YOUR NOT MAKING DUST...YOU ARE COLLECTING IT! SOUTH CAROLINA. |
| Forum | Topics |
Woodworking Skill Share
8793 |
Woodturning
223 |
Woodcarving
28 |
Scrollsawing
61 |
Joinery
80 |
Finishing
1534 |
3550 |
15785 |
Hand Tools
2036 |
Jigs & Fixtures
495 |
Wood & Lumber
2841 |
809 |
Focus on the Workspace
902 |
766 |
Woodworking Trade & Swap
2740 |
LumberJocks.com Site Feedback
1547 |
Coffee Lounge
6159 |
