Jewelry Box Inserts
Forum topic by MOJOE posted 487 days ago 4020 views 0 times favorited 14 replies Add to Favorites Watch
View MOJOE's profile
MOJOE
533 posts in 1438 days
487 days ago
I’m wrapping up a small jewelry cabinet for my daughter. Can anyone point me in the direction of somewhere I can find foam inserts to add to the drawers? Namely, I’m looking for something to hold rings. Since the drawers are already made, I’d need this to be “cut to fit”
Thanks
joe
-- Measuring twice and cutting once only works if you read the tape correctly!
14 replies so far
View ShaneA's profile (online now)
ShaneA
3965 posts in 768 days
#1 posted 487 days ago
Rockler carries some, but I am not sure if they are cut to fit, kind of spendy too.
View poopiekat's profile
poopiekat
2832 posts in 1904 days
#2 posted 487 days ago
Wow! I am about to make the drawers for a jewelry box also! I have pondered whether that peel-and-stick weatherstripping foam would work. what I had in mind was that 1” X 1” gray foam that goes around window A/C units. Problem is, it’s butt-ugly! I’ve also wondered about red chenille, or velvet, but unsure what people are using underneath it for support. I thought maybe that rigid styrene foam that florists use, covered in red chenille, but I don’t want to re-invent the wheel if there is a standard, more typical way that others are using. Most jewelry boxes listed in ‘Projects’ show no detail about what was used for inserts. C’mon, guys, help us out!!
View Tootles's profile
Tootles
657 posts in 671 days
#3 posted 487 days ago
If you need to cut foam yourself, the best thing to do it with is an electric carving knife.
Otherwise if you could get the material bits made up, perhaps you could stuff them with teddy bear / soft toy stuffing.
-- I may have lost my marbles, but I still have my love of woodworking
View gfadvm's profile (online now)
gfadvm
6639 posts in 860 days
#4 posted 486 days ago
I made my own ring holder inserts by cutting slits in high density foam and then covering it with ultrasuede folded down into the slits before the glue set up. Worked super.
MOJOE
#5 posted 486 days ago
gfadvm…..I was thinking about that myself…..might be the best option for a custom fit application.
Thanks guys!
joe
View paulw2's profile
paulw2
13 posts in 502 days
#6 posted 485 days ago
I know that amazon sales there faux velvet/foam inserts for jewelry boxes with small slits in them for rings. The material is soft enough for you to cut and there are enough slits you can spare.
-- Paul, Pennsylvania, http://www.RemodelingContractorPA.com
View live4ever's profile
live4ever
981 posts in 1180 days
#7 posted 485 days ago
This may help….
http://www.woodsmith.com/files/issues/197/make-a-ring-holder.pdf
View Kent Shepherd's profile
Kent Shepherd
2690 posts in 1456 days
#8 posted 485 days ago
I just made some using styrofoam from tool packing. I cut a slit part of the way through on the table saw.
Then I put a little Titebond glue (don’t use CA glue—trust me on this!!!!) in the slits and forced the velvet in with a steel ruler. The principal is much like the link live4ever just posted. I wraped the ends, put a little more glue there, and tucked it in to the tray.
poopiekat
#9 posted 484 days ago
liveforever: Wow! Thanks for the link! That is the best suggestion I’ve seen, and I’m going to Michael’s for the necessary supplies. Thank You for taking the time to provide this info! I hope Mojoe and others find this info useful as well.
View adaughhetee's profile
adaughhetee
80 posts in 853 days
#10 posted 484 days ago
Here is the link to what rockler sales but, at $1 an inch I would make my own. http://www.rockler.com/product.cfm?page=9875 I have used the method show by live4ever but instead of rolling batting into roll’s I used the grey foam insulating rope. I’ve found the batting to be lumpy and loose shape easily.
live4ever
#11 posted 484 days ago
No problem poopiekat, glad it helps!
Now if someone could share a high-quality affordable option for necklace hangers/hooks I’d be much appreciative! The Brusso necklace pegs are like $5 a pop and not a great option when your “client” wants a lot of hooks!
View Roger's profile
Roger
9191 posts in 973 days
#12 posted 484 days ago
here in Louisville, we have a flea market that comes around every so often, and they have many vendors. It’s held at the fairgrounds. there are 2 or 3 vendors there with a nice variety of inserts of all sorts n sizes for jewelry boxes. other than that, this internet should yield something
MOJOE
#13 posted 484 days ago
Thanks again guys…..the insulating rope sounds like a good option to me!
poopiekat
#14 posted 484 days ago
I’m planning to use those ‘cup hooks’ for necklaces. Or, possibly those 90-degree hooks, whatever I can find that looks right and has a yellow aureate (like polished brass) finish. Dollar-Rama here I come!
