Layout, cutlist, plans software
Forum topic by Havasumatt posted 01-21-2012 06:10 PM 19601 views 2 times favorited 4 replies Add to Favorites Watch
View Havasumatt's profile
Havasumatt
30 posts in 2223 days
01-21-2012 06:10 PM
Topic tags/keywords: resource layout software cutlist plans
Hey there fellas! Was wondering if anyone uses layout software? Seems it would save alot of time and wood. I usually stare at a sheet for a while tryin to find the least amount of cut off. Seen a few programs but they’re not cheap at all. Any info on cheap ones or even free ones would be appreciated!
View greatview's profile
greatview
128 posts in 3029 days
#1 posted 01-21-2012 06:31 PM
I’ve used Maxcut
It is free! Works really well for sheet goods.
-- Tom, New London, NH
View Peter Oxley's profile
Peter Oxley
1426 posts in 3746 days
#2 posted 01-21-2012 06:35 PM
View Lifesaver2000's profile
Lifesaver2000
551 posts in 2983 days
#3 posted 01-21-2012 06:57 PM
I use a free standalone cutlist program available at:
http://delphiforfun.org/programs/cutlist.htm
It is mainly for sheet goods, but will work with any size stock you enter. Does a pretty good job. Just one hint though. It will continue searching through many thousands of possibilities, even though it will find a usable one within seconds most of the time. So you just have to stop the search once it shows it has found a solution.
View JAAune's profile
JAAune
1772 posts in 2188 days
#4 posted 01-23-2012 12:17 AM
I am using the cutlist plugin for Sketchup as well. The only issue I’ve had with it so far is the program’s assumption that the largest dimension is always the length of the component. Other than that it’s been a great free bit of software.
