dog hole plugs?
Forum topic by Jeremiah posted 01-21-2012 05:09 PM 2981 views 0 times favorited 5 replies Add to Favorites Watch
View Jeremiah's profile
Jeremiah
82 posts in 2410 days
01-21-2012 05:09 PM
Topic tags/keywords: dog holes workbench bench top
i’m designing a “real” work bench. I’m making the top a torsion box design with dog holes in it.
I use my bench for everything so it gets dirty and constantly has small parts on it. Anyone come up with an inexpensive way to plug the dog holes when not in use, so i don’t end up filling them up with junk?
I’ve thought about turning plugs but i can see them getting stuck and then how do i get them out without having to use tools or screws (as handles)
Any and all actual or theoretical ideas welcome.
Thanks,
JD
5 replies so far
View gfadvm's profile
gfadvm
14940 posts in 2776 days
#1 posted 01-22-2012 04:15 AM
I use plugs like you describe and poke a sharp awl in the top to lift them out. Haven’t had one get stuck yet. The awl will stick in the end grain pretty well if you make your plugs from a softer wood like pine or fir. If one does get stuck I plan to just run a screw in and pull it out.
View handi's profile
handi
154 posts in 4525 days
#2 posted 01-22-2012 04:54 AM
The dog holes in my bench are drilled through so dust and chips don’t collect. I don’t bother with plugs, but if you counterbore the dog holes slightly you could turn some plugs with a wider cap so they do not fall through. Then if needed you could push them up from below.
Ralph
-- Watch Woodcademy free on Amazon Prime! www.woodcademy.com
View Sylvain's profile
Sylvain
709 posts in 2585 days
#3 posted 01-22-2012 12:53 PM
does your bench need to be flush when your dealing with small parts?
Otherwise make mushroom plugs
-- Sylvain, Brussels, Belgium, Europe - The more I learn, the more there is to learn
View KayBee's profile
KayBee
1083 posts in 3332 days
#4 posted 01-23-2012 12:12 AM
Just make more bench dogs and fill the holes with bench dogs. Here are a few examples.
http://lumberjocks.com/projects/59130
http://lumberjocks.com/projects/56298
-- Karen - a little bit of stupid goes a long way
Jeremiah
#5 posted 01-23-2012 04:29 PM
Thanks everyone for the ideas. I’ll have to post some pics when I’m finished with it.
-JD
