Zero Clearance BS Plate
Forum topic by will delaney posted 01-21-2012 04:30 PM 998 views 0 times favorited 2 replies Add to Favorites Watch
View will delaney's profile
will delaney
325 posts in 2601 days
01-21-2012 04:30 PM
Topic tags/keywords: bandsaw
I just purchased a zero clearance plate for my Grizzly bandsaw. With a tablesaw zero clearance plate you just raise the blade through the plate to make the kerf. What is the best way to set up the plate for a bandsaw? I do have 5 chances to get it right but the first time would be nice. Thanks for you help. Will
2 replies so far
View Bill White's profile
Bill White
4903 posts in 3926 days
#1 posted 01-21-2012 09:35 PM
Set the blade guides as normal, remove the blade, drop the upper arm to the new insert while it is in place, use the guide opening as a marking indicator, mark the new insert, put the blade back on the saw with the original plate in place, and saw the opening in the new plate.
That’s what I would do. There may be a better way…......but that’s what I did on my BS (not a Grizz though I wish).
Bill
-- bill@magraphics.us
View NBeener's profile
NBeener
4816 posts in 3140 days
#2 posted 01-21-2012 09:51 PM
I simply used a straight edge to create a set of lines (straight edge against one side, then against the other) that were parallel TO my blade, popped out the ZCI, re-inserted the original plate, used IT as a base, and cut a slot about half-way across the diameter of the ZCI.
‘zat make sense ?
-- -- Neil
