Should I upgrade my benchtop table saw?
Forum topic by Beginningwoodworker posted 139 days ago 231 views 0 times favorited 9 replies Add to Favorites
Beginningwoodworker
452 posts in 154 days
139 days ago
I am wondering should I upgrade my Delta benchtop table saw, its a good saw I have use it on a lot of projects, I am wondering should I replace it done the road. I really love my saw I done cut lots of hardwood on it. but what I dont like about it that I cant rip wider boards. Now I dont know if a bigger table saw will fit in my shop.
-- CJIII Future cabinetmaker
View runngt's profile
runngt
107 posts in 220 days
139 days ago
I would think this is a decision only you can make. How often do you need to rip wide stock. If the need is there and you have the space and funds go for it, you could make a new wood worker a great deal on your delta to get him started also!
runngt
-- It seem's I just make scrap wood and saw dust most of the time !
9026 posts in 303 days
139 days ago
Charles,
Making sure the saw will fit in your shop is the main criteria on which to base your decision. With a benchtop you can build a mobile workstation around it to make it more versatile. This mobile station was posted by gwurst. You can add supports for ripping sheet goods, a downdraft table and router table and make it mobile so that it can be stored out of the way when not in use.
Hope this helps.
View tenontim's profile
tenontim
913 posts in 225 days
139 days ago
I agree with Scott. If you’re low on space, make the saw you have work. Those Delta saws can also benefit from a better, thin kerf blade, like a Forrest. It will help the motor not be bogged down while cutting.
-- Tim -- http://tmuli.com
Beginningwoodworker
139 days ago
I dont have to rip wide boards all the time, the max I have rip is 8’’. I have a Freud 50 tooth combo thin kerf blade in my table saw.
Beginningwoodworker
139 days ago
I work out of a 10×12 shed.
View GaryK's profile
GaryK
8482 posts in 469 days
139 days ago
It sounds like you like what you have. I would upgrade only if I required it.
Beginningwoodworker
139 days ago
Yes I do really like it GrayK I done had it for 2 years or more.
View Jarrod Zion Murphree's profile
215 posts in 204 days
139 days ago
I’m with those guys. Keep it until it peters out, and then get something bigger/better. A hybrid or contractor saw is perfect for a hobbyist, and you can get really nice ones for relatively cheap. I had the Ridgid TS3650 (from Home Depot) for 4 years, and I can recommend it.
-- Jarrod, Eagle Nest, NM http://anthologyfinefurniture.wordpress.com
teenagewoodworker
2025 posts in 249 days
139 days ago
if you feel that you might need it but are aprehensive to go out and spend a lot of money you might want to go and look for a used one. check out this one that i just go used and i love it.
http://lumberjocks.com/topics/3409
Bookmark And Share This Page
