More questions for the Bandsaw Gurus
Forum topic by Letorix posted 01-20-2012 04:10 AM 1380 views 0 times favorited 9 replies Add to Favorites Watch
View Letorix's profile
119 posts in 2436 days
01-20-2012 04:10 AM
Need help picking new tires and blades, help identifying rail for fence.
I have a Jet WBS-20-1 older bandsaw, I need to replace the tires and the blade, the blade that came with it was welded improperly so there is about a 3/8” variance in movement of the blade.
I found these Carter tires:
and these Olson tires:
but I measured the diameter of the wheels and their like 19 5/16 dia. So I’m wondering if either of those tires will fit.
Also I measured the width of the wheels and they are 2” wide and those are less than 2”
I measured the blade plus a previous owner had written inside the machine as 156 5/8”, Looks like the highland wood slicer has a good following here, what blade would you suggest for non-resaw use?
Also any idea of the make of the fence that used this rail? It mounts underneath?
Thanks again Gurus!
9 replies so far
View Loren's profile
10096 posts in 3581 days
#1 posted 01-20-2012 05:09 AM
The Urethane tires stretch a lot to fit. They are made smaller
than the stated size.
There’s a guy on ebay who will make any size tire you need in
orange Urethane. Very reasonable price and shipping included.
Fast too.
#2 posted 01-31-2012 05:27 AM
Arrgggh! I can’t seem to get the wheels clean. I’ve been soaking them in mineral spirits and using scrapers and wire brush. The only thing that seems to work is a scraper. Acetone evaporates too quick, what other solvents can I try?
This should not be this darn difficult! I’ve got most of the old rubber off but I still keep finding small grooves of the stuff here and there…not to mention all of the old adhesive.
View kizerpea's profile
774 posts in 2300 days
#3 posted 01-31-2012 03:13 PM
i bought my rubber from carter..guides to…did it all at one time. got the bandsaw tuneup dvd free. to stick the tires i used the old style gasget shellac. have to got to older hardware stores to find.
View woodklutz's profile
221 posts in 2701 days
#4 posted 01-31-2012 03:37 PM is in my opinion the best place for blades fast inexpensive shipping and great sewrvice.
-- honing my craft one mistake at a time.
View KPW's profile
226 posts in 2302 days
#5 posted 01-31-2012 03:44 PM
Try using lacquer thinner on the old rubber. I got my blades on amazon. Lots of choices, short $
-- Ken --------- never try and put 5 lbs. of tenon in a 3 lb. mortise.
View Bertha's profile
13510 posts in 2626 days
#6 posted 01-31-2012 03:52 PM
For anything bandsaw, I’d contact Iturra.
Order line: 904-642-2802
If that guy doesn’t know, it probably isn’t known.
#7 posted 01-31-2012 04:21 PM
Thanks guys!
I’ll pickup some lacquer thinner today.
View Bill White's profile
Bill White
4878 posts in 3893 days
#8 posted 01-31-2012 05:35 PM
Acetone and lacquer thinner…..Uh…kinda the same thing. Both evap real fast. Be careful about fumes. BOOM!
The Woodslicer is not an all-purpose blade. It is for resawing.
#9 posted 02-02-2012 03:16 AM
Thanks for all the suggestions, still would love a different cross cut and general purpose blade but this wood slicer seems like it’ll do fine for rsawing. Sure is a lot smaller than the 1 3/8” blade I took off.
I’m really pleased with everything now the blade is tracker true…when I get some time I’ll see if old blade didn’t track due to tires or a bad weld.
