Baby It's Cold Outside
Forum topic by HamS posted 01-20-2012 03:04 AM 1227 views 0 times favorited 6 replies Add to Favorites Watch
View HamS's profile
HamS
1812 posts in 2297 days
01-20-2012 03:04 AM
Topic tags/keywords: question
Winter in Indiana is not like some places, but the shop was pretty cold tonight. I have managed to keep it from getting below freezing by judicious use of the wood stove, but it is closer between fires these days and tonight it is probalby going to get below 15F outside. At 5:30 it was 18 outside and 40 in the shop. I just came in from stoking the fire and it is now 75 in the shop. My experience is that it will be around 35 in the morning when I go out before work to relight the fire. I don’t work on good projects until the weekend when I can keep the shop heated all day. I did make a glue up of a skinned frame tonight, using TBII. I am sure it will stay above 55 for the 30 min of setup, but it will get below 55 sometime in the 24 hour full cure time. Has anyone experienced temp related glue failures?
-- Haming it up in the 'bash.
View NiteWalker's profile
NiteWalker
2736 posts in 2485 days
#1 posted 01-20-2012 11:15 PM
I do all my glue ups indoors now. Too cold out in the shop, an uninsulated garage.
View oxyoke's profile
oxyoke
57 posts in 2262 days
#2 posted 01-21-2012 06:24 AM
I live in Michigan.I also heat with wood.It gets cold enough at night to freeze my coffee pot if I leave coffee in it.I do alot of glue ups.I have never had a problem. ——-titebond 2
-- Bill Byron Center MI
View Nighthawk's profile
Nighthawk
554 posts in 2265 days
#3 posted 01-21-2012 06:27 AM
So far I have been lucky we don’t get the extremes here… and have noticed that it doesn’t get to cold downstairs…yet ( I say yet as only been here for 1 winter)
-- Rome wasn't built in a day... but I wasn't on that job? ... http://www.wackywoodworks.co.nz
View derosa's profile
derosa
1572 posts in 2744 days
#4 posted 01-21-2012 07:06 AM
I’ve been using tightbond 3 in the shop. Mine is above the kitchen and off the upstairs hall. It has gotten cold enough to freeze water and the glue still seems to hold just fine.
-- --Rev. Russ in NY-- A posse ad esse
Rick Dennington
5699 posts in 3103 days
#5 posted 01-21-2012 08:49 AM
I have a 40×50 shop, and I have central heat and air, with 10 heat registers in the ceiling. I have blown insulation in the walls, and about 16” blown in the ceiling, so my shop stays warm inside, but on really cold nights, say around 7-10 degrees and below, I turn the heat on about 68, and it stays nice and toasty….never had anything to freeze, especially glues and finishes…....
View KevinWelp's profile
KevinWelp
17 posts in 2210 days
#6 posted 02-11-2012 05:17 PM
I too use TitebondII, in small garage/shop. I can usually keep it around 40 with a infrared heater going constantly. Not sure about today, It was below zero last night in MN.
-- Kevin - Rochester, MN
