Harvet Table
Forum topic by lennyv posted 01-19-2012 11:32 PM 4363 views 0 times favorited 3 replies Add to Favorites Watch
View lennyv's profile
lennyv
4 posts in 2976 days
01-19-2012 11:32 PM
Topic tags/keywords: tip resource
I would like to build a harvest table for my daughter but I’m not sure what determines a harvest table. I’m looking for some ideas.
-- Lenny, Athol MA., Leonard.venett@verizon.net
3 replies so far
View ELCfinefurniture's profile
ELCfinefurniture
112 posts in 2290 days
#1 posted 01-20-2012 12:04 AM
Harvast tables were used throughout history for large feasts and gatherings. Therefor they are very long (6 to 8 feet or so) and they have hinged drop leafs on either side. They appear narrow when the leafs are dropped giving them a distinct appearance. As for the base it depends on the style really. From a trestle to shaker style with leg and apron assembly. Even federal with double pedistals.
But that is the basic idea behind a harvest table.
-- {Current North Bennet street school student}
lennyv
#2 posted 01-20-2012 02:45 PM
I’m presently looking for some rough cut barn board and if I can find 8 foot boards I will try to make an 8 foot table. I’m going to assume that the drop leafs had strap hinges. Some one has told me that benches were used as opposed to individual chairs. Thank you for the great information.
View Ed Pirnik's profile
Ed Pirnik
83 posts in 2800 days
#3 posted 01-20-2012 04:57 PM
Hi Lenny,
I knew we had a harvest table plan floating around somewhere at Fine Woodworking. Here’s a link to Becksvoort’s article:
http://www.finewoodworking.com/PlansAndProjects/PlansAndProjectsPDF.aspx?id=2813
You can get a better idea of the hinge style from the attached detail screenshot I took of the article. In addition, you’ll need a “rule” joint between the edge of the tabletop and where it meets with the drop leaves. Also a spin-out support for the drop leaves.
Good luck!
Ed
-- Ed Pirnik, Fine Woodworking Web Producer
