Tips on using Sketchup
Forum topic by botanist posted 01-19-2012 09:56 PM 1312 views 0 times favorited 5 replies Add to Favorites Watch
View botanist's profile
botanist
167 posts in 3415 days
01-19-2012 09:56 PM
Hey Folks, got a question for ya.
I’m pretty good at designing projects in Sketchup and running Cutlist, but there’s a problem that I’m still having, and that’s creating blueprints.
I can use the cut list output to size all of my pieces, but I still need a guide for putting everything together correctly. Does anyone have any tips for creating good blueprints to follow from a Sketchup model? I can apply dimensions and create different scenes, but it’s pretty clunky, especially if I need to look at a piece in a couple of dimensions. I’ve contemplated making copies of different pieces, but I’m not really sure if that’s the best method. Any help would be appreciated.
5 replies so far
View PurpLev's profile
PurpLev
8534 posts in 3525 days
#1 posted 01-19-2012 10:18 PM
I’ll usually do separate scene with a breakdown of parts involved in any mini-assembly and add relevant measurements on 1-2 sides. there is no magic tool to do this as far as I know, and this is where people really like using Layout and the Pro version of SketchUp for those purposes exactly
View Richard's profile
Richard
1916 posts in 2567 days
#2 posted 01-19-2012 10:42 PM
Check out this site http://www.srww.com/blog/?p=117 he will also respond to your questions and give you help on issues with Sketchup, I know because he helped me out of a problem I was having.
View americancanuck's profile
americancanuck
367 posts in 2486 days
#3 posted 01-19-2012 11:50 PM
What I do is simply bring the laptop into the shop. When I need dimensions or a different view of some part its all there.
-- Retired and lovin it
View BobLang's profile
BobLang
149 posts in 3277 days
#4 posted 01-20-2012 02:19 AM
There is an infinite amount of space in SketchUp (at least I haven’t found the end of it yet) and you can copy the entire model with a couple clicks of the mouse. To generate different views, I just make copies of the model, and set up scenes to show what I want. Here is a link to a pdf file with a bunch of illustrations, all of which came from a single SketchUp model.
http://readwatchdo.com/2011/12/free-stickley-book-rack-plan-format-experiment/
Bob Lang
-- Bob Lang, https://readwatchdo.com
View NelsonP's profile
NelsonP
12 posts in 2196 days
#5 posted 01-20-2012 04:24 AM
I love SketchUp! Everything always lines up and joints are perfect!
The way I do it is by ensuring that each individual piece is promoted to a component (not a group). A change to a component will be automatically reflected in all copies of that component.
After creating my individual components, I join them to create what i would call my assembled project. I name this scene “Assembly”. I then copy the entire assembled project to a different area of the work space and pull all the components apart, add labels, etc.. I call this one “exploded”. I continue doing this to create as many “scenes” as I think I need to create the project.
The beauty is that if I decide to make a change, It will be reflected in all the scenes automatically (including measurements).
-- -- Nelson
