Spice cabinet with hidden compartments
Forum topic by MichaelAgate posted 01-19-2012 02:00 PM 5376 views 0 times favorited 7 replies Add to Favorites Watch
View MichaelAgate's profile
MichaelAgate
398 posts in 2231 days
01-19-2012 02:00 PM
Topic tags/keywords: question plans spice cabinet
Anyone know of a good spice cabinet plan? Looking for one with the secret compartments. I may just draw one up. Would be nice to see others and possibly alter to my needs.
-- Michael and Matthew
7 replies so far
View ksSlim's profile
ksSlim
1271 posts in 2797 days
#1 posted 01-20-2012 07:56 AM
Fine Woodworking mag featured one as a project couple of years back.
google Pennsylvania spice cabinet+plans. several sources
http://www.finewoodworking.com/item/20165/pennsylvania-spice-box
-- Sawdust and shavings are therapeutic
MichaelAgate
#2 posted 01-20-2012 02:54 PM
KsSlim – I actually found it. GoogleBooks has it. Traditional Furnituer Projects. Putting the link below as well. Also, thanks for digging around to find the link you put up.
http://books.google.ca/books?id=8rPqI843igMC&pg=PA44&lpg=PA44&dq=Pennsylvania+Spice+Box+dimensions&source=bl&ots=MvzLV2fWHk&sig=I1mFy50OUaTcKK8fx9hz-m5CG6c&hl=en&sa=X&ei=JeoYT-mpBezq0QGLkcHSCw&ved=0CFkQ6AEwBw#v=onepage&q=Pennsylvania%20Spice%20Box%20dimensions&f=false
View Les 's profile
Les
201 posts in 2598 days
#3 posted 01-20-2012 04:08 PM
If you have any small bit of wall space you could go for a built in model. A face frame and door to match you cabinets and you can slip it in between studs. You can even put a header at the top and bottom and span 2 stud width. Maybe not what you are looking for but just an idea.
Les
-- Stay busy....Stay young
View StumpyNubs's profile
StumpyNubs
7538 posts in 2708 days
#4 posted 01-20-2012 04:19 PM
That’s a LOT of spices!
-Jim; aka “Stumpy Nubs”
(The best woodworking show since the invention of wood.)
-- Subscribe to "Stumpy Nubs Woodworking Journal"- One of the crafts' most unique publications: http://www.stumpynubs.com/
MichaelAgate
#5 posted 01-20-2012 04:23 PM
les,
Beautiful piece, beautiful. Deff a great idea. You certainly have lots of storage there. thanks for sharing.
View Les 's profile
Les
#6 posted 01-20-2012 04:25 PM
You know, if your going to do it….......hey I just build it I don’t fill it. :-)
View helluvawreck's profile
helluvawreck
30164 posts in 2774 days
#7 posted 01-20-2012 05:46 PM
Les, if you make a hanging cupboard that has crown molding a good place to put a secret compartment is in the space between the top of the cabinet and the top of the crown molding. A lot of the times this space is open but it can be closed up easily. there is a Tauntan book that shows a secret compartment where the back panel slides down revealing a compartment like this. If I’m not mistaken this book shows some good pictures about how to do this with a cabinet. it made a pretty slick secret compartment.
helluvawreck
https://woodworkingexpo.wordpress.com
