Shopsmith Lathe Center Alternatives?
Forum topic by ARTTdylan posted 01-18-2012 10:20 PM 8723 views 0 times favorited 5 replies Add to Favorites Watch
View ARTTdylan's profile
ARTTdylan
73 posts in 3086 days
01-18-2012 10:20 PM
Topic tags/keywords: question lathe turning
The shopsmith lathe center that comes with it doesn’t grab like any of my other lathes. Are there any alternatives out there?
I am refering to “A” on this page http://www.shopsmith.com/ownersite/catalog/l_lathecenters.htm
as for the “D” center, we turn pretty large items… for a shopsmith so that probably won’t work.
-- Dylan - www.arttwood.com -
5 replies so far
View richgreer's profile
richgreer
4541 posts in 3098 days
#1 posted 01-19-2012 01:36 AM
I used to use my ShopSmith as my lathe. I don’t anymore. When I used the ShopSmith as my lathe, I noticed the same problem.
I started using my chuck, whenever I could in place of my lathe center – even on spindle turning. 90% of the time you can use a chuck in lieu of the lathe center. On those occasions when I really needed a good lathe center I used a good (not ShopSmith) lathe center that I clamped into my chuck. I needed to change the jaws on the chuck to hold the lathe center. It worked great. I could use any lathe center on the market.
Caution – When doing this, you should consider whatever lathe center you buy as dedicated to the ShopSmith because the jaws will damage the Morse Taper.
View shipwright's profile
shipwright
7992 posts in 2821 days
#2 posted 01-19-2012 02:14 AM
I have an adapter for my chuck that goes from the SS 5/8” straight to the same thread as my Delta lathe at home. From there I can use any spur center I want
View SASmith               's profile
SASmith
1850 posts in 3011 days
#3 posted 01-19-2012 03:14 AM
I use “A” in the above link. I drill a hole in the middle of the spindle then tap it enough with a rubber mallet to make the X indentation. I then cut the X with a pull saw ~1/4” deep. It seems to give a good bite this way without risk of splitting the spindle.
The best upgrade I have made to my shopsmith was a live center for the tailstock.
Do you have a live center on yours?
-- Scott Smith, Southern Illinois
richgreer
#4 posted 01-19-2012 05:15 AM
SASmith – - Before I went to the chuck approach I described above, I used your technique. It worked well. I just found it more time consuming and a bit more of a hassle than I cared for.
ARTTdylan
#5 posted 01-23-2012 04:03 PM
I do have a live center. I think we are going to end up welding something. Appreciate the input.
