| Forum topic by karen12 | posted 518 days ago | 768 views | 1 time favorited | 1 reply | ![]() |
518 days ago |
Well I’m learning to scroll saw and due to the fact this is the cheapest way to go This is what I’m learning on. I heard you cant stain baltic birch cept llike sheila landry does with staining and antiqueing medium and acrylic mixed with it. I would like to try that to make some wood tones but what other ways can you do things with the wood? I’m making a scrolled stand to hold three small candles and then I’m also making some 10 to 12 inch clocks. the clock part is a flower with the face in the middle and the other clocks are mini clocks on a stand and have different themes like aquatic and a bird sitting on a branch.Some of these might lend themselves to painting so the details of the items would stick out. I dont know what kind of paints to use or what to do to the wood except for sanding it. I hear of so many different things my mind is getting all boggled down if tons of info. i think I should start where im at which is these items Im getting ready to make. If I wanted to leave the baltic as is. how does that procedure go? brush on tongues oil and then I get foggy. do I sand it after each time I brush on the tongues oil and it dries? See im a mess. I just need procedures on how to do and when to fo it. I like high glass finish when all is said and done whether its paint or if its natural. hope someone has enough time to help. I sure would appreciate it. I’ve been reading for days |
