reducer vs lacquer thinner
Forum topic by simmers posted 01-18-2012 04:05 AM 5052 views 0 times favorited 6 replies Add to Favorites Watch
View simmers's profile
simmers
17 posts in 3432 days
01-18-2012 04:05 AM
When mixing with Mohawk stains/dyes, what is the difference between using their $25 per gallon reducer and lacquer thinner?
Isn’t there a chemical that you can add to the lacquer thinner to make it less volatile?
Thanks
-- simmers
View ,'s profile
2387 posts in 3511 days
#1 posted 01-18-2012 04:13 AM
I use lacquer and and lacquer thinner a ton, but never use any Mohawk stains/dyes. So I am not sure I know much about your question. If the product you are using is lacquer/solvent based then you can thin with lacquer thinner.
I am not aware of any chemical that would make lacquer thinner less volatile. I don’t know exactly what you mean about lacquer thinner being volatile. I do not find lacquer thinner to be volatile. If you take necessary precautions, such has not spraying while smoking or spraying around any open flames and such. More information is needed to better answer you.
View Clint Searl's profile
Clint Searl
1533 posts in 2325 days
#2 posted 01-18-2012 05:02 PM
Straight acetone can be used as a reducer for any solvent based lacquer product. The product MSDS gives information about volitility.
View Bill White's profile
Bill White
4901 posts in 3924 days
#3 posted 01-18-2012 05:44 PM
Use acetone and have plenty of ventilation unless ya REALLY wanna get “gassed”.
Bill
-- bill@magraphics.us
simmers
#4 posted 01-19-2012 12:30 AM
I apologize, but I meant something to ‘retard’ the lacquer. I assume that Mohawk’s reducer is nothing more than thinner with some additive. I don’t know what it is.
Thanks
-- simmers
View Sawkerf's profile
Sawkerf
1730 posts in 3032 days
#5 posted 01-19-2012 12:39 AM
Have you asked Mohawk’s Tech Support about this? I suspect that it’s analogous to using flow products in paint. They thin the paint for better flow out without diluting it.
404 - Not Found
2544 posts in 2933 days
#6 posted 01-19-2012 01:23 AM
There are different thinners depending on what you want to do and unless you want to take a chance on compromising the finish, the thinners recommended by the finish manufacturers are the ones to use. Becker Acroma is about the standard finish available here and they have thinners for ‘anti bloom’ and to retard drying. A gallon costs almost as much as a gallon of lacquer.
