Who has a pin router - overarm router?
Forum topic by Loren posted 01-17-2012 10:14 PM 9038 views 0 times favorited 21 replies Add to Favorites Watch
View Loren's profile
10371 posts in 3641 days
01-17-2012 10:14 PM
I just acquired a “mid-sized” (about 700lbs and 7 feet tall) overarm
router by Delta/Invicta. It was a bargain, not a phase problem, small
enough to not dominate my shop, and I’ve wanted a real pin router
for awhile.
Of course CNC has replaced pin routers for a lot of things, but the
pin router table tilts no there’s a way to cut angled mortised on
curved chair backs and so forth.
Anyway, is anybody here really using a pin router?
21 replies so far
View helluvawreck's profile
helluvawreck
31013 posts in 2859 days
#1 posted 01-17-2012 10:25 PM
We don’t have a pin router at the plant anymore. I wish that we did. You can actually find them at a bargain usually at industrial woodworking auctions for as little as $250 or so sometimes. You can do a whole lot with them and the jigs are easy to make. They usually have far more HP than any router you’re going to find. usually along with the router you will also see a whole batch of cutters and bits that they used with the router.
helluvawreck
https://woodworkingexpo.wordpress.com
117083 posts in 3570 days
#2 posted 01-17-2012 10:25 PM
Enjoy Loren,I hope it’s does what you need to do. If I recall you have fairly tight quarters in your shop like I do .I hope you can squeeze it in ok.
#3 posted 01-17-2012 10:35 PM
I’ve owned a little one for years and it’s the fastest way to excavate
channels or bushing-guided router jigs. It was really helpful when
I tooled-up to build classical guitars but not nearly heavy enough to
do the cavity routing electric guitar and bass guys do with them.
I may put the smaller one in storage after I get the new one set up.
We’ll see. It’s real convenient to just set up a fence and plow a groove
with an overarm router. I don’t want to imply they aren’t dangerous
machines, but in my experience I can set up and make cuts in
a sort of more intuitive and fluid way than is normally feasible with
router table or topside router type setups.
View cabmaker's profile
cabmaker
1730 posts in 2802 days
#4 posted 01-18-2012 12:03 AM
Loren, a pin router was one of the most unused tools in my shop of long ago. It was bigf and heavy. Its long gone now but it is only in the past few years that I wish I still had one on occasion. I am also a big fan of the invicta series from the early eighties. If you can find a spot for it I bet youll enjoy it and if not let me know what sorta deal we can work out and meet halfway (which is probably around 600miles). Thanks,JB
View Gene Howe's profile
Gene Howe
10472 posts in 3421 days
#5 posted 01-18-2012 12:29 AM
Mine is made by Shopsmith and not nearly as heavy duty as yours. It has a 1 hp PC router in it now. I use it a lot for multiples of curved work. Wife and I made a batch of toy cars and trucks for our local toys for tots. I modified the plans so that one fender style fit every thing. Cut them all out on the OPR, 6 at a time.
Made 8 mirrors and 8 candy dishes for her siblings (big family!) for our last reunion. It came in handy then, too.
#6 posted 01-18-2012 02:42 AM
BTW, I found machine searching my local craigslist business
section, not tools. The same seller had a behemoth 16” sliding
table saw for sale at a jawdropping low price… 3ph and super
heavy and all that, but a tank of a machine.
View doninvegas's profile
doninvegas
334 posts in 2900 days
#7 posted 01-18-2012 03:16 AM
I have this.
-- "Courage is being scared to death -- but saddling up anyway."
#8 posted 01-18-2012 03:21 AM
I had one of those Veritas steel router tables for several years. I really
liked it. I only sold it because I moved cross-country and didn’t work
wood for a couple of years.
How do you like the pin router arm?
It’s more like an Onsrud setup that way… you referenced the cutter
and the surface being cut on the same plane. With an overarm,
the reference surface is opposite the surface being routed, which
is good for some cuts and not so great for others.
View kizerpea's profile
kizerpea
774 posts in 2360 days
#9 posted 01-18-2012 05:56 AM
I have the shopsmith overarm 80s model proly use it once a month.. good machine for the $50 i have in it
-- IF YOUR NOT MAKING DUST...YOU ARE COLLECTING IT! SOUTH CAROLINA.
View tom427cid's profile
tom427cid
294 posts in 2463 days
#10 posted 01-18-2012 08:13 AM
I have a Stanley(mounts on the bench)-havn’t ever seen another-that was made to accept a portable router. Sorta looks like a drill press. It can be used as a pin router-pin mounts on the bottom. Currently I have it set up like a horizontal mill with a sliding table. I picked it up many years ago and only in the last couple of years did I start to use it. Wish I had had it many times before that. Now I use it fairly frequently.
tom
-- "certified sawdust maker"
View TCCcabinetmaker's profile
TCCcabinetmaker
932 posts in 2348 days
#11 posted 01-18-2012 07:58 PM
I’ve used a couple different versions, but to be honest I can’t even remember why I had to use them. The applications were so few and so limited I mostly never went near those machines. And honestly, it can almost always be done another way just as well.
-- The mark of a good carpenter is not how few mistakes he makes, but rather how well he fixes them.
#12 posted 01-18-2012 08:07 PM
I guess it depends a lot on the style of work you do. I don’t like
pattern routing with a full depth piloted cutter and the pin router
allows pattern cutting to be done in multiple passes. Even with
a shaper, more setup is required to cut out patterns in multiple
passes.
I used my smaller pin router lots for making router jigs. It was
a fast and intuitive way to do it. Custom guitar builders still
consider the pin router essential.
Gene Howe
#13 posted 01-18-2012 10:05 PM
I forgot to mention that it makes quick work of drilling shelf pin holes.
#14 posted 01-18-2012 11:39 PM
Gene, do you use some sort of jig for drilling the holes?
TCCcabinetmaker
#15 posted 01-19-2012 04:21 AM
Gene, that’s done just as easily on a drill press. I’ve got a simple jig that one day I’ll remember to take pictures of to show for boring adjustable shelf holes, and even the european hinge borings.
