Spline cutting jig
Forum topic by Gareth00 posted 01-17-2012 04:37 PM 3007 views 0 times favorited 9 replies Add to Favorites Watch
View Gareth00's profile
Gareth00
21 posts in 2212 days
01-17-2012 04:37 PM
I’m a beginner. Could anyone direct me towards a video or plan (preferably both) to help me make a spline cutting jig, please?
9 replies so far
View JFobare's profile
JFobare
41 posts in 2947 days
#1 posted 01-17-2012 04:49 PM
I hope to make one similar to Smitty’s/David’s jig here…http://lumberjocks.com/projects/59266
Hope this helps…
Joshua
Gareth00
#2 posted 01-17-2012 05:46 PM
Thank you Joshua. That certainly is a thing of beauty. I hope I have the skills to make something like that.
View rance's profile
rance
4255 posts in 3036 days
#3 posted 01-17-2012 07:51 PM
Gareth, here’s the one I use:
Gareth00
#4 posted 01-17-2012 10:51 PM
Thanks Rance, I reckon I can manage that. The backer board prevents tear-out?
View bobsmyuncle's profile
bobsmyuncle
110 posts in 2566 days
#5 posted 01-18-2012 01:31 AM
I’m not one to spend a lot of time on a jig. Mine is a piece of scrap plywood and a piece of scrap 1×4. Similar to Rance’s, but I don’t use a lot of 2×4s.
I mitered the 1×4 about in the middle at 45 degrees.
Glued the 1×4 pieces onto the face of the plywood with the back of one at 45 degrees to the edge, and 90 degree center angle. Let the glue dry.
Set up your rip fence and put the plywood against it. Rip your slot. Adjust the fence and repeat. Done.
Toss the jig in the can or stash it away where you can find it again.
View doncutlip's profile
doncutlip
2832 posts in 3431 days
#6 posted 01-18-2012 01:34 AM
you could also enter ‘spline cutting jig’ in the search box, you’ll get tons of results – but the first one posted here is one of the best
-- Don, Royersford, PA
rance
#7 posted 01-18-2012 07:37 AM
Gareth, Here’s an example of tearout.
Having a zero insert plate on your table saw, or a sacrificial fence on your miter gauge can prevent this. The backer board on the spline jig serves the same purpose after you cut several slots in the jig and it is no longer tight up against the sides of your TS blade. Google Tearout for more information.
Here’s another example:
View FaTToaD's profile
FaTToaD
394 posts in 3016 days
#8 posted 01-18-2012 11:31 PM
Here’s the one I made, I use it all the time. It’s similar to Smitty’s minus the stop blocks:
http://lumberjocks.com/projects/34220
I didn’t include the stop blocks because I just clamp piece of scrap to the jig itself. Most of the stuff I cut on it is small enough I just hold it in place with hand pressure.
One tip though, I have found that I get much better results if I push the piece through the blade, lift the piece off the jig, then pull the jig back through the blade. That way you won’t mess up the kerf if it moves on you slightly. And since I hold mine in by hand, it’s bound to happen at the worse time.
If I was gong to make a new one, I’d have a replaceable backstop to prevent tearout. Just a little tearout can ruin the look of the splines.
Hope this helps, let me know if you have any questions about my jig.
-- David
Gareth00
#9 posted 01-30-2012 07:19 PM
Thanks once again to all who responded. I’m making the jig next weekend.
