Glue ups of angled pieces
Forum topic by Philzoel posted 01-17-2012 04:26 AM 1847 views 0 times favorited 6 replies Add to Favorites Watch
View Philzoel's profile
Philzoel
302 posts in 2252 days
01-17-2012 04:26 AM
Just glued up tumbling block end grain cutting board. Thought I could just set up a square corner and start putting the 32 blocks together.
That did not work. Then started gluing a row at a time. Better but but not dead on. Ended up with 64th gaps in angles and edges.
2 questions:
1. can I prevent this? I know the angles and dimension were with in 12 thousands.
2. if gaps are inevitable, how do I fill for good look? Cherry, walnut and hard maple. Sawdust/glue maybe but this is cutting board.
I have glued up many angled long pieces with great success. 32 pieces all angled and nested were a challenge. Any suggestions?
-- Phil Zoeller louisville, KY
View Jim Finn's profile
Jim Finn
2622 posts in 2831 days
#1 posted 01-17-2012 05:33 PM
tough question. I also await an answer.
View SASmith               's profile
SASmith
1850 posts in 2896 days
#2 posted 01-17-2012 07:48 PM
This blog shows some creative clamping.
-- Scott Smith, Southern Illinois
View CCWoodcrafts's profile
CCWoodcrafts
37 posts in 2952 days
#3 posted 12-22-2012 04:38 PM
I just emailed Degoose to ask what he does. He makes many of these so he probably has a great easy way we are not thinking of.
View RetiredCoastie's profile
RetiredCoastie
999 posts in 3092 days
#4 posted 12-22-2012 04:56 PM
SASmith posted a link to my blog. As stated in my blog I lay all the triangle pieces out in manageable sections and I check for gaps and then adjust by sanding each triangle until the gaps are closed and intersecting lines are straight. Once the sections are glued up I then put the sections together dry and repeat the sanding process again until the gaps are gone and the intersecting lines are correct and then I glue and clamp in the clamping jig. It requires an investment of time and elbow grease if you want tight fitting pieces and straight lines. In the end you’ll be rewarded with a beautiful board. I’ve built 6 boards with this method and they all came out straight with no gaps. It worked for me. The biggest and most important factor is starting out with a dead on square saw as this will save you the most aggravation.
-- www.thepatriotwoodworker.com Proud Supporter of Homes For Our Troops
116912 posts in 3486 days
#5 posted 12-22-2012 05:36 PM
Wow I missed that original post Mike,That’s an amazing clamping set up you made plus the fabulous boards you make.
Merry Christmas to you and your wife and whole family.
RetiredCoastie
#6 posted 12-22-2012 05:51 PM
Thanks Jim and Merry Christmas to you and your family!
