How big can a shelf be before it needs to be supported?
Forum topic by Phiz posted 01-17-2012 03:39 AM 1095 views 0 times favorited 3 replies Add to Favorites Watch
View Phiz's profile
Phiz
5 posts in 2343 days
01-17-2012 03:39 AM
One more question, before I actually start finalizing the design of my bookcase.
I was planning on just making a dado for the shelves and reinforcing it with screws or dowels. The shelves will be 3’ x 1’ (originally 2×1 but apparently I misheard the dimensions my wife wanted) , and the sides of the bookcase will probably by 3/4”. I am thinking they will all be oak.
At what point do I need to support the shelves? Will they just tear out of the wood when they are loaded with books?
-- - Jeff
3 replies so far
9770 posts in 3522 days
#1 posted 01-17-2012 04:07 AM
You’ll probably be fine with dados and oak. Loaded heavily a 36”
3/4” oak span at 12” deep may visibly sag a bit if loaded with heavy
books, but it won’t tear out of dados. Add a 1.5” wide board to
the front of the shelf to stiffen it and sag will not be a problem.
View bondogaposis's profile
bondogaposis
4529 posts in 2226 days
#2 posted 01-17-2012 04:16 AM
Well books are heavy and 1/16” deflection will be visible. For 36” I would add front lip That is 1” wide and I believe that will add enough stiffness so that there will be visible deflection.
-- Bondo Gaposis
View quartrsawn's profile
quartrsawn
146 posts in 3088 days
#3 posted 01-17-2012 04:48 AM
Checkout the Sagulator @ woodbin.com .
-- Nat - West Sayville,L.I., NY
