Bench top planer.
Forum topic by PCM posted 01-16-2012 10:31 PM 3398 views 0 times favorited 22 replies Add to Favorites Watch
View PCM's profile
135 posts in 2981 days
01-16-2012 10:31 PM
SOS! My Delta 12.5 inch planer died. I’m looking to replace it. My budget is upto $600.00 but if I could keep it under $500.00 it would be better. I am a hobbiest. Any suggestions or comments would be welcome. Does anyone have experience with the new Delta 13 inch planer? Thanks for you help.
22 replies so far
View papadan's profile
3584 posts in 3304 days
#1 posted 01-16-2012 10:34 PM
Go with Ridgid or Dewalt for the best bang
View richgreer's profile
4541 posts in 3010 days
#2 posted 01-16-2012 10:47 PM
The subject of benchtop planers comes up on these pages often.
If there is a consensus, I believe it is this – The DeWalt 735 is a great planer – perhaps the favorite if price is not an issue. The DeWalt 734 is a very good planner at a much lower cost. I’m a relatively active hobbyist, but not a pro. I stand with those who think that the 734 is more than adequate and, on a benefit/cost basis, I think it is preferable to the 735.
I don’t mean to disrespect the Ridgid or any other brand. I just have no experience with them.
FYI – I have owned a 733 (predecessor to the 734) for over 10 years of virtually flawless operation. It has never let me down.
View Coupe06's profile
6 posts in 2621 days
#3 posted 01-17-2012 12:34 AM might try just swapping out the power switch to see if that’s all the problem there is…
‘Just sayin’...
-- Coupe06-Actual
View Bill White's profile
Bill White
4880 posts in 3896 days
#4 posted 01-17-2012 12:43 AM
It died? Why? Bunch of ? come to mind.
If it is REALLY dead, look at the DW 734 or 735 for good stuff. I have a 733 that has been a beast, and the knives are sharpenable.
View PCM's profile
#5 posted 01-17-2012 01:09 AM
The planer is really dead, I believe a bearing failure lead to the pully attached to the planer head to bend and possibly its shaft. The motor still works fine. I estimate the cost of repairpricing out parts and doing it myself to be at leat $150.00. Its simply not worth it for an 8 year old planer with no guarentee it would work.
#6 posted 01-17-2012 01:10 AM
Bill – I’m not 100% certain, but I believe I have read that, while our 733s have sharpenable blades, the 734 does not. I see that as a relatively minor issue. Depending on usage, you would probably need to replace the blades on the 734 every 2 to 5 years.
Someone else may be able to confirm or correct my statement that the 734 blades are not replaceable.
View Viking's profile
880 posts in 3131 days
#7 posted 01-17-2012 01:19 AM
Amazon has the Dewalt 735 with folding indeed / out feed tables, extra set of blades, and free shipping for $599. Added advantage is no sales tax which about another $50 savings.
I have had this planer for a couple of years and very pleased with it performance. It is 2 speed and blades can be flipped when first side gets dull.
Good luck with whatever you select.
-- Rick Gustafson - Lost Creek Ranch - Colorado County, Texas
Bill White
#8 posted 01-17-2012 01:21 AM
Rich, I sharpen the 733 blades. The reversable “upgrades” can’t be touched up in the shop if anywhere else. I was just spouting about my old and trusty 733. It really jerks my chain that the 735 has OPTIONAL in/out feed tables. For that kind of bucks, why aren’t the tables included? I’m over my whining now.
View gfadvm's profile
14940 posts in 2626 days
#9 posted 01-17-2012 01:25 AM
Ridgid is my choice: Great warranty, comes with tables, their ‘disposable’ blades resharpen well, and I get no appreciable snipe after adjusting my tables.
#10 posted 01-17-2012 01:33 AM
Bill White;
Think our posts crossed. See above where the tables are included as well as an extra set of blades.
My planer gets used a lot and I have about 2 years on first side of original blades. Still cuts with smooth finish that I can start sanding with 220 grit. I will admit that I have only planed clean wood.
View pintodeluxe's profile
5596 posts in 2749 days
#11 posted 01-17-2012 01:48 AM
Dewalt 735 for sure. You will need to get the stand and extension tables. I paid $275 for everything used.
At any rate get one with a chip ejection fan (like the 735 has). That fan helps keep the machine clean inside, which in turn improves quality of cut. Even with my dust collection attached, the internal fan is a big help.
I don’t think the two vs. three blade is all that important. One speed vs. two isn’t all that useful either.
Trust me on the fan.
View MichaelR's profile
42 posts in 2365 days
#12 posted 01-17-2012 02:38 AM
Had a Delta 12 1/2” for 8 or so years. Great small lunchbox but it broke and too costly to fix it. I bought the Ridgid and don’t like it. Never could get the snipe out of it and it needed a total setup out of the box. Blades weren’t sharp, table adjustment didn’t want to hold without loctite and anything over 1/32” bogged it down. That I attribute completely to the blades and setup.
Ran across a used DeWalt 735 and love it. I don’t know if I could afford full price for one. I would buy the Delta 13” if something happened to the DeWalt. Just another opinion.
View doninvegas's profile
334 posts in 2843 days
#13 posted 01-17-2012 02:54 AM
I have had the Delta 13” for about 8 years. I really like it. Keep the tables adjusted and there is no snipe. I flipped the blades about a year ago and the still cut clean. It is starting to act up a bit though. Think the rollers are starting to wear out. I have to give my boards a push to get them through. I have cleaned the rollers and waxed the bed but it didn’t help much. I this thing ever dies I’ll probably get the DeWalt 735 because of all the great reviews.
-- "Courage is being scared to death -- but saddling up anyway."
View toolie's profile
2117 posts in 2564 days
#14 posted 01-17-2012 04:13 AM
ridgid 4330. once registered with their lifetime service agreement, all repairs (parts and labor) are covered for life and are free to the tool’s original owner.
-- there's a solution to every just have to be willing to find it.
View NiteWalker's profile
2736 posts in 2513 days
#15 posted 01-17-2012 05:06 AM
Spend $569, get the DW735, and this one comes with the tables and an extra set of blades. I was dead set on the DW734 but this deal has me reconsidering.
Deal Link
