9" Craftsman Bandsaw hums- will not start
Forum topic by Jim Jakosh posted 01-15-2012 05:37 PM 5681 views 0 times favorited 15 replies Add to Favorites Watch
View Jim Jakosh's profile
Jim Jakosh
21953 posts in 3340 days
01-15-2012 05:37 PM
My friend bought a used 9” Craftsman bandsaw for us to use out here in the desert. It worked when he got it but now it just hums and will not start. I don’t see a capacitor on the motor so I thought it might be a bad spot on the armature. He rotated it and it still hums.
Any ideas?
Anyone have one of these saws that might have been through this problem?
Thanks, Jim
15 replies so far
View crank49's profile
crank49
4032 posts in 3205 days
#1 posted 01-15-2012 06:25 PM
Maybe the bearings are packed with dust. Not seized but dragging too much for the motor to spin.
View tchaser's profile
tchaser
37 posts in 2925 days
#2 posted 01-15-2012 06:34 PM
take the blade off and see off it will run and see if there is a bind on either top or bottom wheel. if not then it is probably a motor issue. if it is a bind then you probably have a bearing issue. to double check start spinning by hand and see if the motor will kick if so its a the motor more than likely.
-- bad projects make good firewood
View BobM001's profile
BobM001
388 posts in 2565 days
#3 posted 01-15-2012 06:52 PM
Make sure that the blade guide blocks aren’t to tight. Back them away from the blade. Do a thorough cleanup of the saw’s interior to eliminate any issue with dust packing .
-- OK, who's the wise guy that shrunk the plywood?
View robert triplett's profile
robert triplett
1566 posts in 3339 days
#4 posted 01-15-2012 06:59 PM
I had an issue with my urethane tires rubbing the housing and melting a bit on my Delta. the saw wouldn’t budge. Took the tires off and adjusted the tracking.
-- Robert, so much inspiration here, and now time to work!!!
24808 posts in 4085 days
#5 posted 01-16-2012 12:00 AM
Not with the bandsaw but had a similar problem with the linisher and a pressure washer. A new capacitor fixed the pressure washer.
If you don’t see a capacitor it may have worn armature brushes which may be obtainable,but I have limited knowledge of electricity other Jocks may have a better idea. In any case a new set of brushes is not expensive.
View Bob Collins's profile
Bob Collins
2603 posts in 3918 days
#6 posted 01-16-2012 12:27 AM
When I got my 9” bandsaw (not a Craftsman) the motor would hum when turned on but no blade movement.
Loosened off the blade and guide blocks and all is well,
-- Bob C, Australia. Your best teacher is your last mistake.
View Nighthawk's profile
Nighthawk
556 posts in 2591 days
#7 posted 01-16-2012 01:25 AM
Sounds like the bushes are gone…???
-- Rome wasn't built in a day... but I wasn't on that job? ... http://www.wackywoodworks.co.nz
View paratrooper34's profile
paratrooper34
915 posts in 3186 days
#8 posted 01-16-2012 02:29 AM
I have a small bandsaw similar to yours. If I torque the blade tension too tight, the motor just hums and will not turn the wheels. Maybe that’s it.
Good Luck.
-- Mike
View sedcokid's profile
sedcokid
2735 posts in 3833 days
#9 posted 01-16-2012 03:00 AM
Sure sounded like a dead spot in the windings to me!! Don’t know what the humm would be.
take care there Jim!!
-- Chuck Emery, Michigan,
View mafe's profile
mafe
11771 posts in 3323 days
#10 posted 01-16-2012 03:05 PM
Sorry no idea, hope it will start running.
good luck on it,
Mads
View Woodbutcher3's profile
Woodbutcher3
454 posts in 3121 days
#11 posted 01-16-2012 09:21 PM
All the suggestions above are good ones. I’d start with a thorough cleaning inside and out, wheels and motor. Sometimes they just need the care they lacked before you owned it.
I had to take the blade bearing guides off a bandsaw I got from ny dad. The grease hadn’t been changed (Packed) since he bought it – I know I used it back in the mid 60’s. So it’s at least 45 yrs old.
-- Rod ~ There's never enough time to finish a project, but there's always time to start another one.
Jim Jakosh
#12 posted 01-17-2012 07:57 PM
Hey, thanks for all the good suggestions!!
I brought the saw over to our site yesterday thinking I would remove the motor and clean it out for starters.
Well. I first opened the covers and gave the pully a spin and it ran just fine. I shut it off and it would not start by itself.
I noticed that it has some funny guides. The left ones are at 45 degrees to the blade and the right ones are square. I backed off all the guides and she took right off every time. It seems that lower left guide was bearing too hard on the blade and that little 2.5 amp motor could not overcome the friction to start. I set all the guides to just”kiss” the blade and she is up and running fine. I sliced off some tree blanks for today’s projects and it cuts great.
G’day, Bob. You hit it on the head!!
Maybe this will help someone else who has this problem in the future…....Jim
Thank you all for the good suggestions!!
#13 posted 01-19-2012 07:27 AM
A great result Jim and at no cost, thats even better.
Jim Jakosh
#14 posted 10-02-2013 12:44 PM
As Sarah Palin would say, You betcha!!!!!!!!
BTW, he took that saw home and bought a Grizzly 14” one from Craigslist!
cheers, Jim
View bigblockyeti's profile
bigblockyeti
5310 posts in 1955 days
#15 posted 10-02-2013 01:55 PM
These smaller motors with no start capacitor have little starting torque to overcome any load that might be more substantial at idle than at speed where they make there power.
