Makita Planer
Forum topic by Praki posted 142 days ago 240 views 0 times favorited 4 replies Add to Favorites
View Praki's profile
Praki
76 posts in 478 days
142 days ago
Topic tags/keywords: tool planer
Hi All.
I am considering buying a planer. I don’t think I will be using more than a few hundred board feet of lumber in a year. My top three choices are Dewalt DW735, Delta 22-580 and Makita 2012NB. Personally, I am leaning towards the Delta (as it includes the feed tables and GaryK seems to like it a lot!). There are a lot of good reviews for the Makita online but not on LJ.
Before I pull the trigger, I would like to know if buying the Makita is a good idea (it is 1 inch less capacity and I don’t know if it really matters). If I could have a Makita user weigh in on this, it would be very helpful. Thoughts on other makes are also very welcome.
Thanks
-- Praki, Aspiring Woodworker
View David Freed's profile
David Freed
41 posts in 148 days
142 days ago
About 16 or 17 years ago I bought a Makita 2040 15 3/4” planer. It was a good, very strong machine, all except for its motor. I somehow got the idea that it had a 5 hp motor on it. I thought I had read that in the description, but after I got it, I found out it was absolutely gutless. If you fed a board in according to the instructions it would pull the motor down really bad. The motor is hidden up under the base and when I laid the planer over to look at the motor, it was small enough to hold in one hand. I had a 3 hp industrial motor on hand, so I made some major modifications (way too big to mount under the base) and when I was done it was a very usable machine. I never could find out how many hp the stock motor was supposed to be, but it only weighed about 20 lbs. I probaby ran 10,000 to 15,000 bf through it after I fixed it. I got a bigger planer and sold the Makita to my neighbor. It’s still going strong.
-- David, Southern Indiana, http://www.freedhardwoods.com
View GaryK's profile
GaryK
8482 posts in 469 days
142 days ago
I don’t know much about the Makita, but I don’t think you could go wrong with either the Delta or Dewalt.
9026 posts in 303 days
142 days ago
I am with Gary. I have the 22-580 and have run several hundred feet of cherry, maple and oak through it over the last 3 years and it has not given me any problems.
Praki
141 days ago
David, Gary and Scott – thanks for weighing in. I will probably go with the Delta.
Praki
Bookmark And Share This Page
