Band Saw Help
Forum topic by smitty290 posted 01-14-2012 11:13 PM 1265 views 0 times favorited 17 replies Add to Favorites Watch
View smitty290's profile
smitty290
10 posts in 2365 days
01-14-2012 11:13 PM
I’m just getting starting in woodworking so I have picked up some used tools on craigslist. I got a 10” Delta Band Saw that has never been used, in fact it has never had a blade on it. I may have found out why. When I get the blade in position and tighten the top knob to add tension the blade and top pulley touch the top of the casing before it is tight. Any suggestions on how to correct this issue? Everything appears to be put together correctly.
Thanks,
Ed
17 replies so far
View Joe Davis 's profile
Joe Davis
102 posts in 2458 days
#1 posted 01-14-2012 11:18 PM
could have bought too long of a blade
View syenefarmer's profile
syenefarmer
492 posts in 3105 days
#2 posted 01-14-2012 11:19 PM
The first thing that I would do is check and verify that the blade is the proper size for that saw. From your description it sounds to me like the blade is too long for that saw.
smitty290
#3 posted 01-14-2012 11:33 PM
The sticker on the housing says it takes a 72 1/2” blade. I got a 72 7/16” I’m assuming that’s correct?
Joe Davis
#4 posted 01-14-2012 11:40 PM
are there rubber tires on the blade wheels? or is it bare metal
View doncutlip's profile
doncutlip
2832 posts in 3581 days
#5 posted 01-14-2012 11:42 PM
Could it be something in the tensioner spring?
-- Don, Royersford, PA
Joe Davis
#6 posted 01-14-2012 11:43 PM
the upper metal housing may have been assembled wrong or to low
smitty290
#7 posted 01-14-2012 11:51 PM
It has the rubber wheels on the pulleys they are about 1/4” thick and show no wear which is understandable as it has never been used before. The housing is plastic on this saw. Just going by my eye, it doesn’t appear to be warped at all. @Don, I don’t think it is the spring, the tensioner mechanism goes just about as far as it will travel before the blade is tight and touching the housing.
View poopiekat's profile
poopiekat
4356 posts in 3759 days
#8 posted 01-14-2012 11:53 PM
Is this a 2-wheel model, or a 3-wheel model? I used to own the 3-wheel model, and it took 56 1/8” blades. I’ve bought 57 1/2” blades (that were manufactured for a different saw), and the top wheel hit the housing before the blade was properly tensioned.
View Bill White's profile (online now)
Bill White
4948 posts in 3985 days
#9 posted 01-15-2012 12:36 AM
Wrong blade length.
Bill
-- bill@magraphics.us
View RibsBrisket4me's profile
RibsBrisket4me
1554 posts in 2530 days
#10 posted 01-15-2012 01:36 AM
I had that very band saw, 2 wheel plastic Delta. It worked fine. It has to have been a mislabled or mispackaged blade.
smitty290
#11 posted 01-15-2012 03:53 AM
I got the blade out and measured it, it appears to be the correct blade. Thank you all for the advice. Is there anywhere you can get custom length blades? i could maybe get one 1/2” to 1” shorter and see if it worked?
View ChuckV's profile
ChuckV
3124 posts in 3552 days
#12 posted 01-15-2012 04:14 AM
You could give Suffolk Machinery a call. They manufacture TimberWolf blades. They are very helpful and can make up a blade to the length you want.
-- “Big man, pig man, ha ha, charade you are.” ― R. Waters
View BobAtl's profile
BobAtl
49 posts in 2718 days
#13 posted 01-15-2012 04:15 AM
I had a similar problem with my Delta bandsaw shortly after I bought it. It was 20+ years ago so I don’t remember the details – and they probably wouldn’t be relevent to your problem anyway. But I called Delta and described the problem to them and, since it was under warranty, they sent a rep out to my house to repair it. So my suggestion is to call Delta’s customer service. Have the model number, serial number and any other info available when you call. They’ll likely be able to tell you what’s wrong and how to fix it.
Along the same lines, the worklight on my Porter Cable drill press was damaged when I unpacked it this past fall. I called their customer service and they sent me a new light. I wasn’t sure how to go about the repair (a lot of dismantling of the pulleys, etc. was required) so I stopped by the Delta / Porter Cable service center in Norcross / Metro Atlanta, and the tech there walked me through it so I could complete it at home and not have to load the whole thing up and haul it over to them.
My experience has been they’re very helpful and you’re likely to save yourself a lot of wheel spinning by calling them.
-- Bob, Atlanta
View Dallas's profile
Dallas
3599 posts in 2512 days
#14 posted 01-15-2012 04:31 AM
grab a piece of string and wrap it around the wheels while the saw is set for least tension.
Mark where the string meets itself.
Remove string.
Lay string out in a straight line.
Measure string.
If it doesn’t measure just shy of the correct stated length, one of the wheels is wrong or the saw is put together wrong.
Good Luck.
I still think you have a blade that is too long. ;)
View andysden's profile
andysden
45 posts in 2443 days
#15 posted 01-15-2012 10:11 PM
Split the saw at the upper and lower frame joint and place a 1/8 inch shim or put a longer guide pin and add more shim may have to re aline the frame to make blade run true. Good luck Andy
