Dust collector
Forum topic by Maximillian posted 01-14-2012 10:34 AM 1399 views 0 times favorited 13 replies Add to Favorites Watch
View Maximillian's profile
Maximillian
84 posts in 3190 days
01-14-2012 10:34 AM
Topic tags/keywords: dust collector question
The cloth bag on my dust collector is filthy with dust.
Should I throw it in the laundry machine, or will that ruin it?
-- Max, New Zealand
13 replies so far
View Tyrone D's profile
Tyrone D
314 posts in 2242 days
#1 posted 01-14-2012 10:52 AM
Use an air compressor to blow the dust out. It’s what I do anyways. You should also bang on it to loosen the dust after every session.
-- --Tyrone - BC, Canada "Nothing is ever perfect, we just run out of time."
View Les 's profile
Les
201 posts in 2599 days
#2 posted 01-14-2012 01:56 PM
Turn it wrong side out and shake the h—- out of it, then put it in the washer with COLD WATER and let it air dry and it will be like new.
-- Stay busy....Stay young
View Viking's profile
Viking
880 posts in 3104 days
#3 posted 01-14-2012 02:05 PM
I would not wash it as filtration will be degraded. Just take it outside, shake it well and re-install.
-- Rick Gustafson - Lost Creek Ranch - Colorado County, Texas
View KPW's profile
KPW
226 posts in 2277 days
#4 posted 01-14-2012 02:56 PM
Actually the collection of dust on the inside of the bag makes it filter even finer particles so thats a good thing. Leave it alone until you notice the suction power to be less. Then clean it like Viking says.
-- Ken --------- never try and put 5 lbs. of tenon in a 3 lb. mortise.
4885 posts in 2402 days
#5 posted 01-14-2012 03:15 PM
It may depend on the bag, but AFF told me to never wash their felt bags. As mentioned, the cake is part of the filtering system. A good bag will only hold a proper amount of cake, the rest falls off. Even so, I would clean mine once a year or so. Take it outside, hang it up and beat the snot out of it with a 4’ long 3/4” dowel. On odd occasions, I would turn it inside out and use the shop vac to suck the dust off…once you do that you have to wait for the cake to rebuild.
View HorizontalMike's profile
HorizontalMike
7747 posts in 2823 days
#6 posted 01-14-2012 03:32 PM
I agree on never washing the DC felt bags, just beat on them once in a while. I actually use my old paddle from school. At least the DC works “better” after a good paddling. Can’t say the same for some of my previous students who met Mr. Paddle. ;-)
Rick Dennington
5699 posts in 3103 days
#7 posted 01-14-2012 05:05 PM
Actually,, the best solution is to remove the bags, clean them really good, hide them somewhere, and get a Wynn canister filter for the top, and a clear plastic bag for the bottom…the Wynn filter is the best thing going for d.c. They run about $100 +s&h, and the 35A canister can be retro-fitted to any d.c. Also, when you buy the filter, they send you 3 clear plastic bags to replace the bottom bag, so you can see the dust and chips, and know how full the bag is getting…..best thing I ever did for mine, and they improve the cfms for more suction….once you have one, you’ll never go back to cloth bags again….
View Lee Barker's profile
Lee Barker
2170 posts in 2759 days
#8 posted 01-14-2012 05:23 PM
These are all good thoughts. One variable not mentioned is the actual bag. I have seen them of very different feeling fabrics.
My DC is an old Murphy-Rodgers, a single tall bag. I guess I’d call it felt, though I’m not sure. Occasionally, and especially after using the wide belt sander, I get a handful of the fabric while it’s winding down and shake it vigorously. Some fines come off the outside (I have an air filter right next to it) and a lot of fines drop into the barrel. But I know the bag is still pretty well populated with cake and it brings in the chips and doesn’t emit any visible fines when it’s doing its thing.
The three of us—Murphy, Rodgers and Lee—seem to have reached a very comfortable place in our relationship.
Kindly,
View Lance's profile
Lance
428 posts in 2435 days
#9 posted 01-14-2012 05:32 PM
Turn it inside out, take it outside with the air compressor and blow 60-70% of it off, then take a shop vac and get the rest of it off the bag, this is a long process but works very well.
-- Lance, Hook'em HORNS! ""V""
Viking
#10 posted 01-14-2012 09:35 PM
Max;
You did not mention which DC you have but, as Rick Dennington said, a canister filter will SIGNIFICANTLY improve performance of your system. Most bag filters have a surface area of about 25-35 sq. ft. The Wynn filter has 274 sq. ft. of surface area which results in much higher velocity.
If you install a pre-separator in front of it you may never have to empty your lower catch bag.
Good luck!
Maximillian
#11 posted 01-14-2012 11:24 PM
Thanks guys. I am always impressed by the willingness to help.
The reason I want to do something is that every time I start it it gives off a puff of fine dust. Given that this is likely to be the most harmful sort and that I have developed a persistent cough I need to do something. The good thing is that the doctors have said that there is nothing wrong with me
-- Max, New Zealand
View doncutlip's profile
doncutlip
2832 posts in 3465 days
#12 posted 01-14-2012 11:37 PM
I have a cannister too and it’s well worth the investment. They typically have a self cleaning mechanism but I vacuum mine off once a year or so anyway. If you’re coughing you might at least want to consider a new bag.
-- Don, Royersford, PA
View bbjjj's profile
bbjjj
29 posts in 2240 days
#13 posted 01-15-2012 06:52 AM
I have a 37” Performax dual drum sander and I am using the 1100cfm JET dust collector. It worked well with the original bags but the upper bag would eventually get that thin fine film of dust on the inside. The bags on the JET DC are made from a polyester material, that with a good shake come pretty clean.
I had to reconfigure the DC system and for height restrictions I removed the upper bag and put a solid cover over the opening. I also added a pre-filter cyclone over a container that I made and that takes the place of the lower bag on the DC that collects the dust. Then the lower bag now becomes the final filter. The cyclone is the only way to go, no more cleaning filters and my dust collection performance is at it’s peak all of the time.
I also found some pre-filters that I use in my 10 gal. QSP shop-vac that are made from a slick polyester fabric, when it gets a little clogged you shut off the vacuum and give the whole thing a good shake and the dust falls off the filter and you’re back in business. I have not had to clean the pleated filter since I installed the pre-filter 10 years ago, yes I said 10 years and my performance is the same as having a brand new filter all the time.
