bench vice installation advice
Forum topic by lepelerin posted 522 days ago 2673 views 1 time favorited 8 replies Add to Favorites Watch
View lepelerin's profile
lepelerin
76 posts in 523 days
522 days ago
Topic tags/keywords: bench vise installation apron
Hello,
My first post here, even if I have been reading this forum quite a lot.
Here is my situation.
I want to install a vise (groz DQ-7) on my workbench freshly built. The top of the workbench is made of 2 layers of 3/4 MDF and a 3/4 plywood. There is a glued maple apron (1.25”x3”) around it.
My question is how do I fix the vise to the bench. The bolts’ hole for fixation (close to the back jaw) would have to go through the apron. and the ones further would be fixed into the MDF+Plywood.
I am afraid that fixing a part of the vise into the apron might not be a good idea. It might weaken the apron (only glued). In this scenario, how would you fix the vice?
I would like some recommendations, advice from the experts here.
Thank you in advance.
Arnaud
PS: sorry for my english, not my native language.
8 replies so far
View crank49's profile
crank49
2380 posts in 1169 days
#1 posted 521 days ago
I have two of those vises on my bench.
My benchtop is 3 layers of 3/4 plywood topped with a layer of 1/2” MDF and 1/8” hardboard (masointe) and banded with a 1×4 Maple.
I, too, did not like how close to the edge the mounting holes would be.
I removed a 14” section from the banding, routed a mortise into the plywood layers the same thickness as the iron vise back jaw. Then spaced the vise down so the top of the jaws would be below the masonite top layer of my bench with spacers under the benchtop.
Then I drilled and counterbored holes so I could thru bolt the vise under the bench with the bolt heads in the counterbores and hidden under the top masonite layer of the benchtop and the front of the back jaw behind the maple banding which I then reattached with countersunk brass screws.
Finally, I made me a Maple liner for the front jaw that was flush to the top of the bench and added dog holes in the jaw so I could clamp large flat work against dogs in the bench top.
If I didn’t loose you in all that wordyness, you can see that My Groz vise is very solidly attached to the bench top, the banding around the top passes tight through the vise and is actually the back jaw (and replacable).
This works perfectly for me. Been using it for almost 2 years.
-- Michael :-{| Diapers and politicians both need to be changed often; and for the same reason.
lepelerin
#2 posted 520 days ago
Thank you.
A picture is sometimes worth a thousand words. I will try to figure out how you make your installation. In the worst case scenario, I will contact you again.
Arnaud
crank49
#3 posted 520 days ago
I’ll try to get a picture tonight.
lepelerin
#4 posted 517 days ago
Thank you, it would be greatly appreciated.
crank49
#5 posted 513 days ago
Here is a sketch of the installation method. It shows what is going on better than my photo.
The 1” jaw liner in the sketch is the band that goes around my work bench.
That band/liner is also flush with the leg face so it works like the Roubo style bench. I can clamp long workpieces to the legs for additional support while they are clamped in the vise.
Sorry, I’m a couple days late. Had a big installation project at work.
lepelerin
#6 posted 513 days ago
Thank you very much, awesome.
Arnaud
View DIYaholic's profile
DIYaholic
7583 posts in 873 days
#7 posted 509 days ago
I too, need to install a vise on/into my (very soon to be built) workbench.
lepelerin thanks for asking this question and crank49, thanks for the illustration.
The only problem now, I won’t have anyone, but myself, to blame if/when I screw up my install!
-- Randy-- I may not be good...but I am slow!
View drnick's profile
drnick
3 posts in 417 days
#8 posted 417 days ago
perfect. Thanks for sharing
