Thinking about a turntable....
Forum topic by Kenny Dunn posted 01-14-2012 02:09 AM 1693 views 0 times favorited 4 replies Add to Favorites Watch
View Kenny Dunn's profile
Kenny Dunn
44 posts in 2235 days
01-14-2012 02:09 AM
Wanting to combine two of my passions, wood and music, more precisely, a turntable (I know, why doesn’t he just do a cabinet like everyone else!). Saw this and was really impressed and thinking about doing one myself.
Anyone done one? I was thinking about using solid wood and putting some inlays in there. This one is MDF and they added lead weight for ballast. complete thread is at http://www.diyaudio.com/forums/analogue-source/35189-my-diy-turntables-diy-tonearm.html
Any thoughts? Not sure if solid wood would be the best sonically, would still hollow it out and add some weight (balance issues???). Ideas? Comments?
-- I saw an angel in the marble and I carved until I set him free-Michelangelo
View rance's profile
rance
4256 posts in 3069 days
#1 posted 01-14-2012 02:21 AM
Not having read the article(I will later) I’m guessing MDF was used for stability. “Wood moves, get over it” is a common quote, and it is true. If not MDF, then maybe Baltic Birch plywood. As for ballast, I’m guessing this is to act as a flywheel in evening out any speed consistencies with the motor.
This looks like a cool project. Go for it and report back.
Kenny Dunn
#2 posted 01-14-2012 02:53 AM
You can see lots of pics on the article. I was wondering if wood was too unstable, I mean the tonearm can allow for a small amount of imperfections plus add a nice mat would help too. I would really wanting to throw some walnut and ash pieces in there before she hits the lathe! Also, the weight isn’t so much to maintain speed as it is to make it less sensitive to sonic and other vibrations, but I am sure it helps with speed control, too.
View knotscott's profile
knotscott
7877 posts in 3284 days
#3 posted 01-14-2012 03:51 AM
Wood is more likely to have it’s own sonic character or coloration….you might like it better, you might not. MDF is more inert and acoustically neutral…which I think would be desirable for something like a turntable that should reproduce only the sounds on the recording with as little signature of it’s own as possible. You could add veneer for the aesthetic value. There are other inert choices too.
Kenny Dunn
#4 posted 01-14-2012 03:18 PM
Lokkie here, supposed to be really good
Were manufactured commercially. Its a Grace G-714 if anyone is interested, main aritcle is at
http://www.vinylengine.com/turntable_forum/viewtopic.php?t=8355
