Needing to age a wooden fence
Forum topic by baby86bear posted 01-13-2012 09:24 PM 17780 views 0 times favorited 16 replies Add to Favorites Watch
View baby86bear's profile
baby86bear
15 posts in 2568 days
01-13-2012 09:24 PM
Hello my fellow lumberjocks. I have been asked to replace some old fence board around my aunts house. The fence that is up now has that nice weathered look.
She has asked if i could make the new look like the old that I am leaving up. I was told my a friend that all I need to do is mix one box of baking soda in a spray container with hot water till dissolved and spray the boards.
i have never heard of that??? Please give me advice and i will try them all. and reply with the results.
thanks
baby86bear
16 replies so far
View JNP's profile
JNP
113 posts in 2811 days
#1 posted 01-13-2012 09:46 PM
I’m looking for photos but we torched a fence to “age” it. Used one of the large propane torches used to melt ice and apply roofing. Got it at Harbor Freight
-- Jeff
View Dallas's profile
Dallas
3599 posts in 2721 days
#2 posted 01-13-2012 10:00 PM
Build a box large enough to hold your fence boards, use a jar of ammonia with some steel wool submerged in it. IT should take about 12 to 24 hours to age the wood.
View JNP's profile
JNP
#3 posted 01-13-2012 11:02 PM
Here are some pics…if you want to apply any stain, do it before burning. The heavy black will wear off or can be scraped.
-- Jeff
View Viking's profile
Viking
880 posts in 3429 days
#4 posted 01-13-2012 11:24 PM
I have used a method similar to this before with good result;
1. Shred a piece of steel wool and place the pieces in a jar.
2. Cover the steel wool shreds with white vinegar. Tighten the lid on the jar and leave the steel wool to break down in the vinegar for one or two days.
3. Bring some water to a boil in a saucepan. Pour 1/4 to 1/2 cup of the hot water into a second glass jar. Drop a tea bag into the water. Use a plain, dark type of tea. Place the lid on the jar and allow the tea to steep until the water becomes dark.
4. Paint the wood with the tea, allowing the tea to thoroughly soak into the wood. Leave the wood to dry.
5. Paint the wood with a generous amount of the solution of vinegar and steel wool. Wait for the wood to turn a deep grey color
-- Rick Gustafson - Lost Creek Ranch - Colorado County, Texas
View FenceWorkshop's profile
FenceWorkshop
267 posts in 3358 days
#5 posted 01-16-2012 08:15 PM
baby86bear
#6 posted 01-25-2012 08:08 PM
thanks to everyone for all the great comments. I mixed up baking soda and hot water and sprayed the fence with pump sprayer. looks ok. but, i am going to let nature do the job.
View nikar's profile
nikar
5 posts in 1987 days
#7 posted 08-07-2013 12:03 PM
Hi everyone I am new here and was just wondering if I can get some more info about the torched fence that JNP posted pics of. I am wanting to possibly try this tecnique to a privacy fence we just are putting up. Thanks for the help!
View CharlesNeil's profile
CharlesNeil
2468 posts in 4104 days
#8 posted 08-07-2013 12:54 PM
What is the wood, chemical aging works well, but it depends on the species which technique to use.
nikar
#9 posted 08-07-2013 01:09 PM
The fence wood is pressure treated….pine i guess?? I am looking for something that looks a bit different than what everyone else has and something that doesnt have to be done every few yrs. I will probably just let it age naturally if the only treatment i can find has regular upkeep. Thanks!
View HorizontalMike's profile
HorizontalMike
7770 posts in 3147 days
#10 posted 08-07-2013 01:27 PM
I used a 10% solution of nitric acid (very weak, but use loves anyway) to age the Ponderosa Pine inside of my narrow Amish Cabinet. It goes on like water and colors in about 24hr. Turns gray with occasional flecks. No streaking and it did not matter how much you used, it all comes out uniform. Just my 2-cents worth…
http://lumberjocks.com/projects/86774
BEFORE
AFTER
nikar
#11 posted 08-07-2013 02:18 PM
That looks very nice! Thanks for your 2-cents!!!
View distrbd's profile
distrbd
2252 posts in 2680 days
#12 posted 08-07-2013 06:17 PM
If you like greyish “weathered” look,Minwax stain is not a bad choice:
MINWAX 271 Classic Gray(for “weathered look”)
-- Ken from Ontario, Canada
19570 posts in 2090 days
#13 posted 08-07-2013 07:35 PM
Probably whatever artificial method you use will just make those new boards look different from the naturally aged wood which defeats the purpose. The only thing that ages like the weather is the weather.
View Steve Peterson's profile
Steve Peterson
395 posts in 3316 days
#14 posted 08-07-2013 09:45 PM
Look at any existing fence with automatic watering. The portion that gets hit by the sprinklers is usually much more weathered than the top of the fence. The repeated wetting and drying will rapidly age the wood.
You should be able to speed up the aging process with a sprinkler that wets the boards every hour or two every for about a month. I think that anything else that you do will only match the color for a short amount of time.
Another option is to steal a few already weathered boards from the back fence to put into the front fence. Then put the new boards in the back where less people will see them.
-- Steve
nikar
#15 posted 08-07-2013 10:58 PM
Thanks everyone for your ideas!! I appreciate it!!
