| Forum topic by ldl | posted 498 days ago | 903 views | 0 times favorited | 14 replies | ![]() |
498 days ago |
I have the Craftsman 12” lathe tube type. It is an older model please go to my werkshop and see it. My question is what size, type, etc chuck would be ok for this lathe. I have the spindle drivers and 2 face plates but I want to venture into things I can’t do with these like better methods of holding bowls etc. -- Dewayne in Bainbridge, Ga. - - No one can make you mad. Only you decide when you get mad - - |
14 replies so far
#1 posted 498 days ago |
It’s always hard to tell you what to buy without knowing more about what you want to do. Nonetheless, I offer my opinion. I would recommend against buying some of the cheap stuff out there. A good chuck should last a long time. I own an Oneway Talon. However, I have used a Barracuda that, IMO, was just as good. The Talon came with only one set of jaws (I bought another later). The Barracuda comes with 3 sets of jaws. Advice – A drop of oil every 6 – 12 months on each set of gears will keep it working smoothly. -- Rich, Cedar Rapids, IA - I'm a woodworker. I don't create beauty, I reveal it. |
#2 posted 498 days ago |
I’m thinking about that as well for my HF floor model. Been looking into chucks, and critiques on Amazon. I am ignorant and I am not in an area where I can see something before I purchase it, but spending as much and buying the best you can afford is a good start. Different lathes have thread dimensions as well as adapters so you can fit your lathe. Rich, I’m wondering what IMO stands for? -- Cau Haus Designs, Thomas J. Tieffenbacher |
#3 posted 498 days ago |
IMO – In My Opinion Anyway Doc, I am limited in my lathe experience, but from what little I have learned, most lathes use pretty much the same thread patterns, sizes, and morse taper deminsions, then there’s Harbour Freight. I agree with Rich that if you don’t get more than one set of jaws of different sizes, you will find yourself either being limited or ordering a different sized set. |
#4 posted 498 days ago |
I’m using a lathe that is over 100 years old. I have a couple faceplates and a drive spur but no chucks. It also has a “dead” center that needs lubed with wax regularly. I haven’t looked into a live center or a chuck. If anyone has a link that would show me what is available for antiques like mine, I would really appreciate it! My lathe was made by Greenfield Tap & Die in Greenfield, MA and was driven by leather belts from an overhead shaft. It has served me well for over 45 years and I have no plans to replace it. -- Every day above ground is a good day!!! |
#5 posted 498 days ago |
You might look at the Nova G3. Love mine. Make sure there’s an adaptor available for whichever chuck you choose to fit that lathe. I had one of those that belonged to my dad. Can’t remember the thread size right off hand but I think it was smaller than one inch but I’m not sure. -- Darell, Norman, Ok. |
#6 posted 498 days ago |
I have a Grizz 1067Z lathe. The chuck I bought looks to be a knock off of the Vic Marc VM100. It has been a good chuck. Look it up in the Grizz catalog. I’d buy it again. It is the 3 3/4” chuck on pg. 138 in the new catalog. Gotta check your size/thread of your headstock. Comes with knock-outs, wrenches, screw center, etc. -- bill@magraphics.us |
#7 posted 498 days ago |
Rich the Nova G3 and the Barracuda2 are basically the same price. If you had it to do over would you buy the Barracuda cause of the 3 jaws? Are the 3 Barracuda2 jaws ones that would be normally used. I want to turn bowls and generally do more things with my lathe. I have turned bowls with my faceplates but it is hard to finish the bottoms correctly. -- Dewayne in Bainbridge, Ga. - - No one can make you mad. Only you decide when you get mad - - |
#8 posted 498 days ago |
How would you finish a bottom of a bowl with out a chuck?... -- Chris ~ Central Michigan |
#9 posted 498 days ago |
Any bowl turning I do is mounted to a faceplate. Bottoms are flat and usually just sanded smooth or covered with felt. A chuck would allow me to do a lot more but I have gotten used to what I can do with what I have. If the need for something else comes up I’ll find a way to get it done or buy the tools I need for the job. If you look at some antique woodworking it’s pretty amazing what they were able to do without all the technology that is available to us! -- Every day above ground is a good day!!! |
#10 posted 498 days ago |
When in school 45+ years ago we used card stock and glues it to a board that was screwed to the faceplate. We glue the bowl blank to that card stock with all this centered as well as possible. We never wore any of them home but today I wonder why not? We would finis the bowl and has to make the bottom flat. we used a chisel to separate the paper and remove the bowl from the board. Worked great then. Often wonder about today’s recycled papers. |
#11 posted 498 days ago |
first off let me say, I don’t post much but I do read here alot. http://www.grizzly.com/products/H6264 Page 138 of there catalog. i bought my first for my first lathe which was the same as yours. Just this past week I bought 2 of these chucks for one of the turning clubs I belong to. One last thing, I personally don’t like nova chucks, to me they are backwards, meaning that you turn them counter clockwise to tighten and clockwise to loosen. opposite of the way most things work, I know that some think my reason is stupid but its just a pet peev with me. IAN -- woodturners keep things spinning. |
#12 posted 497 days ago |
Ian do you know which jaws come with the 6264 or can you choose? I couldn’t see anything that said. -- Dewayne in Bainbridge, Ga. - - No one can make you mad. Only you decide when you get mad - - |
#13 posted 497 days ago |
they come with the standard, 2” jaws, also known as #2 or 50mm I think, depending on manufacturer. Ian -- woodturners keep things spinning. |
#14 posted 497 days ago |
Thanks for the info. I am seriously considering this chuck. -- Dewayne in Bainbridge, Ga. - - No one can make you mad. Only you decide when you get mad - - |
| Forum | Topics |
Woodworking Skill Share
8799 |
Woodturning
224 |
Woodcarving
28 |
Scrollsawing
61 |
Joinery
82 |
Finishing
1538 |
3556 |
15818 |
Hand Tools
2040 |
Jigs & Fixtures
496 |
Wood & Lumber
2847 |
810 |
Focus on the Workspace
904 |
766 |
Woodworking Trade & Swap
2742 |
LumberJocks.com Site Feedback
1547 |
Coffee Lounge
6167 |
