Identification of a Weathered and Possibly Old Saw
Forum topic by brokenroads37502 posted 01-12-2012 05:35 PM 947 views 0 times favorited 3 replies Add to Favorites Watch
View brokenroads37502's profile
1 post in 2257 days
01-12-2012 05:35 PM
Hello all,
I’m new to this forum and in fact it’s my first woodworking forum ever. I’m coming to you I hopes of receiving help identifying a saw that my father brought back with him from a class that the Navy sent him to close to 20 years ago. In its current state it is functional but I’m not exactly sure it can live up to its full potential without being given quite a bit more TLC than what my Dad has already given it. I believe that it is the remnants of what used to be a powerful 10” tablesaw due to the way that the arbor mechanism raises and lowers in its current state it is again fully operational and it is also mechanically safe to cut wood with. What I mean by not living up to its potential though is that the arbor has on dual V-belt pulley. Well when he brought it home the saw had no motor as well as no base cabinet. My father constructed a base out of wood as many of you also have done the same I’m sure due to not being familiar with tablesaws he also constructed a mounting system of his own design that allows the motor to hang, rise, as well as lower as you move the arbor up and down. He put a single groove pulley on the motor meaning that it’s not going to run as well as it could with 2 belts attached. The actual mounting bracket is still in tact and attached to the back side of the arbor bracket. But I would really love seeing this saw brought back to its former glory if possible of course. All I can find as far as identification is some casting numbers on the bottom of the table top, under the right table extension, on the trunnions, and the motor mount bracket. Is there a way to ID This Saw using these casting numbers?
Here are the casting numbers as well as the location of where I found them
D-3017-4 Backside of the bracket for the Left-Tilt Hand wheel
D-3017-3 Underside of the Cast Table Top
D-3017-17 Underside of the Right Table Extension
F-3017-7 Motor mount bracket
C-3019-9 Front and Rear trunnions
Any help identifying this saw would be greatly appreciated. If it helps it appears to have a light bluish/ grayish coat of paint on the undercarriage.
Once again thanks
3 replies so far
View DIYaholic's profile
19574 posts in 2605 days
#1 posted 01-12-2012 05:57 PM
Sorry, I’m really no help! Others will chime in, I’m sure. A picture says a thousand words…....
Good luck!
View Dan's profile
3630 posts in 2811 days
#2 posted 01-12-2012 06:16 PM
Delta uses a light bluish/gray color on most of their tools so that may be worth checking into.
-- Dan - "Collector of Hand Planes"
View Dallas's profile
3599 posts in 2418 days
#3 posted 01-12-2012 06:23 PM
Possibly a Duro F3017 or 3018 Click here for photo
