loose hinge - how do I fix it ?
Forum topic by Vjeko posted 01-11-2012 09:32 PM 1418 views 0 times favorited 6 replies Add to Favorites Watch
View Vjeko's profile
Vjeko
135 posts in 3378 days
01-11-2012 09:32 PM
Topic tags/keywords: question
I bought some heavy oak doors from a company and they installed them – unfortunately a couple of the
doors weren’t closing as well as I expected, so I tried to adjust the hinges. I had a bit of a look
for these types of hinges on USA web pages, but it looks like they’re a bit specific to Europe.
Here’s an example of the type of hinge I’m talking about:
http://www.svezakucuidom.com/proizvod.php?id_kat=435&id=4445
The cylinder part is like the steel welders hinges and each cylinder has a threaded part
(one is screwed into the door and the other into the frame – as per usual).
The problem is that in my desire to improve the situation, I just made it worse ;) – on one hinge, the threaded
part which screws into the door frame is loose / not staying vertical – what would be the best way to fix
this ?
-- Vjeko Balas - Croatia
View GregD's profile
GregD
788 posts in 3100 days
#1 posted 01-11-2012 10:25 PM
What is loose?
A joint in the hinge? In that case I imagine you want to replace the hinge.
Or is it the connection between the hinge and the door frame that is loose? In the worst case you can remove the hinge, drill out the hole and glue in a piece of dowel. After the glue dries you can drill the correct size hole for the hinge and re-install the hinge. A short cut that might work is to remove the hinge and coat the inside of the hole with some glue – thick epoxy would be best. What you are going for is not to fill the hole but to make it smaller with a thick layer of glue on the sides. Once the glue is cured try reinstalling the hinge and see if it is sufficiently tight. If not, resort to the dowel.
-- Greg D.
View Dallas's profile
Dallas
3599 posts in 2451 days
#2 posted 01-11-2012 10:43 PM
It looks like there is a threaded insert in the door and in the hinge. I would check to see if that insert is still tight on either side and if not possibly do like GregD said and use epoxy around the insert and let it cure.
404 - Not Found
2544 posts in 2933 days
#3 posted 01-11-2012 10:56 PM
It sounds like the thread has stripped in the frame/carcass. Greg D has the right idea, but how well this would work depends on the type of material the frame/carcass is made from. If you had a plug cutter and the same size bit, I’d make a plug and glue it in instead of a dowel, because with a dowel you will be reinserting it into end grain.
Those hinges are not the best, especially for heavy doors. You might be better off using blum type 35mm, or if you don’t have the tools to fit them, something like these.
http://www.hafele.ie/HafeleIreland35a1/Templates/hafele/Products.asp?param=4907&ig_id=28458&title=Easy+mount+concealed+hinge
http://www.dlawlesshardware.com/anpeovhiinpa.html
404 - Not Found
#4 posted 01-12-2012 03:23 AM
technology failure on above Hafele link, I meant this kind of hinge
Vjeko
#5 posted 01-12-2012 11:29 AM
I was thinking of doing what GregD suggested but wanted to see if there was any other alternative
or specific type of glue or other substance which could be used .
Just to make it clear – if you look at the link I indicated, you have two cylinders
top one is hollow on the inside and the bottom one has the same size protrusion as the hollow section
of the top one. OK, I think that’s clear – so they sit on top of each other and can rotate.
Each cylinder also has the threaded part – one cylinder is screwed into the door and one into the
door frame – directly into wood. The door and frame are made of oak – there are no inserts. The cylinder which is screwed into the door is tight and staying vertical, the one screwed into the frame is not so tight and is leaning.
There are 3 hinges per door.
It is my opinion also that this type of hinge is not the best long lasting solution but unless I replace
all of them, I’m stuck with fixing the one that is loose.
I think I will try what GregD suggested unless someone knows of anything better than epoxy.
View canadianchips's profile
canadianchips
2600 posts in 2961 days
#6 posted 01-12-2012 02:45 PM
A quick fix will be using white carpenters glue and an everyday tooth pick. (Perhaps 2) fill the hole with glue, insert 1 or two tooth picks, rethread the hinge into the hole and let it sit 1-2 hours. Thicker wood sometimes spits the door, toothpicks are soft enough to let the screw bite into it without doing more damage to door itself.
